Hello RandyFL
Sounds like you have your hands full. Considering a WarP 9 or 11 just may be a good idea for the Toyota. The thing I wonder about is combining air conditioning into the package. Volts are RPM's and power is Amp's. The Warp's are using all the amps they can get for acceleration and cooling is for a short time during acceleration is no problem. Adding air conditioning to the equation at this time will still add to the amp draw as if you are constantly accelerating. At once you can see more cooling power is needed. But it is not the cooling I worry about, it is the mileage. On average flat surface, you should expect about 25 miles per charge, shouldn't count on more but always happy to get it. Now, with air conditioning on with effect of amps drawn, might bring mileage to the effect of constant up hill or acceleration. It might be as low as 5 or 10 miles per charge. Not good,,,,,
What we here are trying to do is develop a manor in which Amps are reduced to the point that we can afford them. UFO's all North winding does indicate we are on the correct track. There are many changes needed to bring this system up to the size that will do the Toyota, but we will get there. The current investigation using super capacitors is going well. The cost of super capacitors is shocking but so is a Warp 9. When it all is settled down, we will have a device and system that may well initially may cost as much as the warp 9 but have a much smaller every day cost, as well as greater mileage. My hope is to get to the point of NO daily cost.
This earth of ours is suffering from our chemicals, weather gas or medication. In the long run it does not make sense to use a car that runs without harm, but at the same time, needs heavy charging every day from an electric company or gas company. In effect, we are only changing the location of the chemicals produced.
Go Go Go UFO!
PS
While the days get a bit long here, You might study up on Super capacitors.
' Supercapacitor Auto Balancing using (SAB) MOSFETs '
This is the best information about SC's I have found to date.
All you need to know about Super Capacitors:
Let's learn about Super Capacitors! (A Practical Guide To Super Capacitors)
Where to get Super Capacitors:
Super Capacitors - Engineeringshock Electronics
Where to get mosfets to balance SC's
Invalid Request
super capacitor balancing with mosfet Diagrams
https://www.google.com/search?q=supe...=firefox-a&hs=
0pK&sa=X&rls=org.mozilla:en-US
fficial&channel=sb&tbm=isch&tbo=u&source=univ&ei=
yeKtU77jNYaSqAaej4LQBw&ved=0CDEQsAQ&biw=1280&bih=9 26
Unique MOSFETs Automatically Regulate And Balance Series-Connected Supercaps
http://powerelectronics.com/discrete...-regulate-and-
balance-series-connected-supercaps?page=1
These are not the only locations, but more to get you started...
Dana
Go Go Go UFO!
PS
Invalid Request
![Embarrassment](http://www.energeticforum.com/core/images/smilies/redface.png)
Dana
