  • Magnet motor
    Hi UFO,
    I have a feeling you'll like these mods to the motor. Your work is extraordinary. Keep it coming.
    Free Energy Testes - YouTube
    Free Energy testes 2 - YouTube
    Apologies if this has been posted earlier.
    Muchas gracias,
    HS
    • A Timeless Machine...
      A TIMELESS MACHINE - YouTube
      A "Timeless Machine"...just because it could have been built One Thousand Years ago...without the "Industrialization Age" ...without heavy machinery to build it...Raw...it could belong to many of our Highly Advanced Ancient Civilizations...as it has been built just now...
      An Electrodynamic Machine...built without laminated steel, without steel cores, either at Armature Nor Stators...without Permanent Magnets...just Copper magnetic wire and Wood to support as structural frame...No need of "Industrial Manufactured Parts or Components"...raw wire, raw wood, hand made...and it works...it rotates...
      This Machine proves it is ALL about Magnetic Patterns...that we could create whatever we want...including Electricity, therefore Energy...
      • Also posted on the My Motors got me to Tap into Radiant Energy thread:
        Ufopolitics,
        I do believe the technology you have brought forward is paving the way for the new energy source and social transformation that is needed at this time:
        2012 may bring the "perfect storm" - solar flares, systems collapse
        2012 may bring the "perfect storm" - solar flares, systems collapse - Seattle exopolitics | Examiner.com
        "These new energy sources are less vulnerable to destructive solar storms, have no negative environmental impact, and could unleash unprecedented economic and social transformation."
        Stay the course and never give up!
        IndianaBoys
        PS: What you are bringing forth is a novelty:
        Novelty =
        1. The quality of being new, original, or unusual.
        2. A new or unfamiliar thing or experience.
        Timewave Zero 2012
        Timewave Zero 2012 - YouTube
        Terence McKenna's Novelty Theory
        Terence McKenna's Novelty Theory - YouTube
        Terence McKenna On Novelty
        Terence McKenna On Novelty - YouTube
        Terence McKenna Timewave Zero Novelty Theory 1/3
        Terence McKenna Timewave Zero Novelty Theory 1/3 - YouTube
          you are great ! they way u think and link things in your mind for making it to progress to your goal, is the best i have seen , and then implement it to see it works , to acheive a challenging goal always gives lot of satisfaction, reminds of me of my ealier days .
          i think u can see the magnetic patterns by now
          • Hi Ufopolitics
            bravo
            So i have to go to bench for this replication.
            the other one are very interesting and i am testing a lot of different coils in order to penetrate my understanding of the growing up of the Prinzess.
            will make video of my progress
            good luck at all
            Laurent
            • UFO,
              I am having some problems with my 16 pole motor running, and I have PM'd you about it. Here is a picture of how it is wired.
              I don't know if I did a very good job of showing that it is a split coil and both sides are wound in the same directions. Also, I drew this and those were the only colors of marker I have. I just used color to show that the coils were split in half.
              If I DID wind this correctly, then it is my connections that are the issue and I will deal with that. Also, if I DID wind this correctly, this motor comes factory wound like this if you know what you are doing.
              It is one long wire and the coils are wound in series. All are wound in the same direction. The wire comes up out of the coil, loops around the tab on the commutator and then begins the next coil. If soldering didn't cause you any problems, you could clip each wire AFTER it winds around the commutator and you would have 32 individual coils. You could then find the sets that are across from each other and solder them together to give you your 16 "split coil pairs" and you wouldn't have to rewind the motor at all. You'd have to solder a lot (32) pieces of wire. 16 to connect the coil pairs, and 16 on the ends of the pair to lengthen the wire to get to the commutator on the other side of the armature, unless you unwrapped half a wind on each of the 16, and then they would reach without soldering. Just a thought...and it depends on whether or not I wound this correctly.
              • Hello Turion
                UFO,
                Hello Dear Turion,
                Ok,
                I underlined your wrong conclusions...
                If you have a straight wound coil, that has on one end a North, and in the other end a South...then you split it exactly on its half...and set them right next to each others, in order that their ORIGINAL poles will be facing outwards towards stators...then you will have two coils wound opposite to each others...
                What you are doing on this arrangement is getting a straight [l] Coil and making it a [U] Coil, in order that at both ends of the "U" will be their North-South poles...
                Yes, I know exactly the way they come from "Witch Factory", trust me...nothing like mine...and NO, you can not just cut and solder contacts...not that simple my friend...sorry.
                You have wounded them wrong, because you have two Coils North where a North-South Coils needs to be...so they can not "take off"...One is repelling, one is attracting...equal force...at exactly eight points on motor...is not going to move..
                That is the reason why I said to verify by applying a Compass...and a small 1.5 volt battery to each pair...or a Known Poles Permanent magnet...to see if they are N-S, at each pair...and also making sure which will be your positive commutator...
                Sorry about that Turion...
                • This is why you are running this thread and I am winding coils over and over! LOL. As long as I eventually get it right, I will be happy. So the direction of half of my windings was incorrect, but was the arrangement of windings correct...as in the picture I drew.
                  • Such nice Diagrams I made!!...lol
                    Hello Turion,
                    Ok, I made this Diagram to make it clear...when I was talking about U Shape Axis, and "Split Coils"...
                    Hope it helps you and others...
                    However, if you look closer to My Original BOSCH Diagram below...follow the Blue wire...when entering Poles to become red...(You Must Look at their JOINT Section) all of them are wound opposite, my dear friend...
                    • I put some numbers on the drawing. Which coil is paired with number one? It appears to me to be 2, but it is not on the opposite side of the armature from one, so that is confusing me. Or is one paired with 7? I don't think so.
                      When I wound my coil, I thought the coils were to be on opposite sides of the armature from each other, but I am starting to see that I did not understand this at all, even though I have looked at this thing a hundred times.
                      • Numbered..Coils.
                        Hello Dave,
                        I thought the coils were to be on opposite sides of the armature from each other...
                        The reason why they can NOT be across...is because next matching opposite pair will be exactly at 180º...then, remember what happens?...they cancel on output to a big Zero my Dear Friend...So by putting their Axis at the "U" Shape...I am "fooling" the Vectors...they will never "meet" at opposite... :P
                        Nope, they are right next to each others as pairs...so:
                        Left Upper Coils 3,5 are Pairs to Motor Brush above (top, 12 o'clock)
                        Right Lower Coils 7,8 are Pairs connected to Motor Brush at 6:00 O'clock
                        Pair of Coils 1,2 at Generator Brush 2, at 3:00 o'clock
                        Pair of Coils 6,4 at Generator Brush 1, at 9:00 o'clock
                        Also note Generator Brushes top are Red touching Upper Commutator (Bigger Ring)
                        As Motor Brushes are Black Top/Red Bottom...
                        Now the more effective way to connect Brushes between them...
                        Motor in Parallel Input Positive with Positive, and Negative with Negative
                        Generator Brushes connect them in series...Pos with Neg...and Pos-Neg ends to Output Terminals...
                        Ok...?
                        • Timeless Machine
                          @UFO
                          Thanks for that video AND all the work it took to build that little model. It isn't easy and it takes alot of time. I now understand what you mean about "bending" the two coils out of alignment to get away from the canceling effect and make the generator part work. Your "magnet less" design is something that I have been thinking about doing also.
                          I have been working with my little machine and learning a little more about what is going. I watched Peter's video again (all 2 hours) and that also helped. His "attraction" motor is interesting.
                          @All
                          I hope that the guys building the larger and complex motors have success.
                          @Woopy
                          If you build one of those "Timeless Machine" designs ----I'll be right behind you. I don't know about you but I think that I would use much finer wire and go after reducing the friction big time. The "Witch" takes a big chunk of the energy but that old man "Friction" is real thief.
                          Lidmotor
                          • Timeless Machine
                            UFO,
                            Thanks for sharing, thats real neet (+_+)
                            Mike Klimesh
                            Live to experiment, Experiment to live (+_+)
                            • UFO,
                              I have been looking and looking at the 16 pole armature, and I have to admit, I can't figure out how to wrap it. If I wrap either three poles with spaces between them or four poles without spaces between them, the positive poles on the rotor are directly across from the negative, which you have said is not acceptable. If I wrap three poles with NO spaces in between them, I am left with a gap of four spaces when I finish. If I wrap three and three (double space) three and three (double space) I have negatives and positives directly across from each other again. All I can figure is a triangle wrap with five on two sides and six on the third.
                              I included a blank picture hoping you might be able to help me
                              • Hello UFO and all
                                I'm working here at my motor..
                                I found that i wound it completely unbalanced
                                and made a drawing now of how i think it would be in balance
                                can anyone help me with that?
                                check it out
