Originally posted by machinealive
Motor does 7000 RPM's IF, I hook ALL in Parallel, 40V at FULLY Charged Bank.
And watch Video 1 better...with Turbo Boost it reaches over 5000 RPM's
You should run a LOAD TEST on your Batteries...sometimes Batteries show full voltage but when you apply load they drop very low or even zero...and you just need one bad battery there to ruin your whole bank.
I have one of those 100 AMP Load Testers, that by pressing momentary the load (a huge wire resistor hold by insulation), the needle will drop to either "good" or "bad"...Now there are Electronic ones...but more $$
Something like this...
So, going back to Your Generator Hook up...just get Pure Generator total output...when turning it with Motor connected externally with the Diodes. However there are many tests you could do there...You have your hands full...
