Material from My First Thread...
Hey Cornboy,
Yes my Friend, that is Material I disclosed on my First Thread here...
Even the reversed flow from a Standing Coil...pulsed, could turn on a whole Symmetrical Motor...running cooler, no arcing/sparks...and much faster then using Hot feed...just Radiant flow.
A Stator is just a Coil...same as the ones I used there...we just named them "Stator Fields"...simple coils of wires...like an Inductor...a Transformer or else...
Kogs ran a Symmetric Motor (Happy Motor Diagram) with his pulsed coil reversed flow...
Now, when you feed rotor coils from stator reversed flow like Diagram shows...besides saving Energy...your rotor will spark much less...and will run close to ambient temperature...![Smile](http://www.energeticforum.com/core/images/smilies/smile.png)
But let's think a bit deeper here...
If Rotor Input (through Brushes) receives the Energy flow ONLY at OFF Times from Stator Pulses...Then ask yourself...Why then, Rotor spins IF "Supposedly" when Stator is OFF Time Feed...there should not be any Magnetic Fields presence?
Further more...If, according to your winding direction, versus projecting magnetic polarity knowledge on Coils...whenever you guys do this experiment...check rotation sense from rotor...and then what should the Stator Polarity be...to produce that direction according to our positioning of Bisectors and Brushes alignment?
![Big Grin](http://www.energeticforum.com/core/images/smilies/biggrin.png)
Originally posted by Cornboy 555
Hey Cornboy,
