By adapting the principal workings of a Fridge a vey low ambient heat turbine drive can be had.
Carbon Dioxide CO2 is now the Refrigerant R744.
The technology posted changes in layout. For temperatures from -10*C to +32*C no boiler is used and the turbine is gas. Temperatures of +32C use the boler/cooler and the turbine needs be Hydro.
Carbon Dioxide the weirdest gas ever. Begins as a block of Dry-Ice. Heat increase changes to gas, then to liquid, then to gas, then to Dry-Ice. It’s the only gas that behaves like liquid.
CO2 gas at temperature above 31.2* will not convert to liquid no matter what compression is applied.
The energies of CO2 are thousands time greater than Steam.
Energy as a force is measure in bar, one bar being the equivalent of 14.2 PSI or one atmosphere.
One litre of Water, Steam or Gas per second at 9 bar pressure passing through a turbine generator produces 720 watts. Any increase in bar pressure or volume per second increases the wattage output.
Working from a base line of 0* Celsius Steam is beginning to format 100*C whilst CO2 has already reached 7,000 bar.
The attached diagram operates in two different mode, the first below 31.2*C using the cooling loop of a fridge to cool the hot gas before going to the compressor which squeezes the gas into liquid before feeding it back in heating point.
The other uses a boiler and exploits the fact CO2 at temperature above 31.2*C formats into Dry-Ice. At 100*C it’s 50/50. 50% Dry-Ice coats boiler ceiling and wall and the other 50% remains high pressure hot gas.
This design does away with the fridge cooling loop and instead exploits the Dry-Ice field constant in the boiler. CO2 though gas but behaving like liquid is force drained from the bottom of the Boiler then piped back through the Dry-Ice field which cools the CO2 gas back to liquid. Hot gas exiting the Boiler forces the cold liquid at the same pressure of the gas exiting the boiler. The cold liquid at force then drives a Hydro turbine which empties into a screw pump Boiler feed. The technology is fully sealed and 100% recycling.
