Mag drive
Hi all, I finally got the magnetic drive to work.
I found that running, using a single coil, I could only put .83 volts into a cap of 16 volts 12000uf.
But by shorting the AC leads of the coil, in front of the caps, I can fill it to capacity , in less than the blink of an eye.
I need more coils , just using the heavy wire coils from MOT's .
Use the full caps to charge the batteries?
Also you need to use ,the anti-vibe to work for you. This has to do with Matt Jones' bouncer project.
That reaction is worth alot .
Use it to your benefit, don't fight it.
Using a VCR motor and flywheel to drive a 72in. wheel , even when you short the coils ,I don't see any drag or reduction in speed....the caps just keep filling up.
artv
artv
