Howdy Carroll,
Thanks for those details, I always appreciate details.
I suspect that the function depends on the inductances in play. Meaning the thing spinning as a generator has to have a relatively High inductance in relation to the transformer thats then attached to it, as that transformer has to have a much lower inductance for it to pull the current out of the higher inductances windings once the transformers secondary is shorted.
In the window motor case you have a pretty low inductance of 517uH and the transformer low volt sides inductance is probably still at least 20-30mH thats been put in relation with the output from your window motor. That might be why the Current is Sitting in the motors windings and creating that lag, instead of pulling the Current over to the trafos windings. Maybe?
As for the drain pump motors, I ended up buying two different ones so I could put one on the kollmorgan motor and one on the DC brushed motor to see how they both worked as drive motors. The first one I got was the all black plastic drain pump motor for a samsung washing machine. That was this one.
DC31 00054A Washer Drain Pump for Samsung PS4204638 AP4202690 Washing Machine | eBay
The one above comes apart oddly, but you can't pull the coils from it as its all one fused plastic motor form. The nice part tho was this one has a metal knub under the impellor once you break it off and you can cut the little key off leaving a nice 1/4inch metal knub on the shaft to put the little spider coupler on.
The second one I bought I got the modular version which let me pull the rotor out, remove the laminates and also pull the coil pack... That was this one:
Drain Pump for Samsung Washer DC31 00054A Washing Machine | eBay
I wanted to try the thing without the laminates to see what the resultant sine looked like, and it was pathetic. Maybe 12vac at the same rpm that we see the 400vac from with the laminates present. So the laminates are necessary given the small reach of the ceramic rotor magnet.
Also this second one has a plastic knub with a key on it too, used the dremel to cut the key off and its also at 1/4inch diameter for the spider coupler. There wasn't much difference between the twos inductances, one was ~131mH and the other at the 152mH mark or so... both are 80watt rated pumps.
Lemme know what else I can help with.
Take care man,
Gene
Take care man,
Gene
Originally posted by citfta
