Hi Bob,
The Longitudinal ampere force is just that an Ampere Current that inrushes the conductors orthagonally aka perpendicularly to the direction that the current elements are laid out and conducting on. Its not the Voltage, its a function of the volts turned pure current due the very low resistance of the current elements, which in that book were defined as two closed circuits that had a DC source to provide constant Very high AMPS thru the pair of elements, each with their OWN source, not shared source, and it was this interaction that occurred when the two current elements were put in local relation which then would cause this massive sideways incoming force to manifest on the wires which would then cause them to go brittle and crack when carrying such huge Amp Currents.
Ones gotta keep in mind that volts to amps is a sliding spectrum. If you have 12volts at 10amps, you could also have 120volts at 1 amp and its the same wattage, just a different "format" of that wattage. You could also have 1.2volts at 100amps... and its the same watts, different "format". In all 3 cases its still only 100watts.
So far GM has yet to stick to one system and actually work thru all the contributing details, instead of doing that he starts new context after context, and in none of them does he bother with details of basic importance such as determining input volts and amps versus output volts and amps.
At this point I've written GM off as now hes on about some RC brushless motor then followed by some 108amp alternator to drive one of his pole pigs... context after context of unfinished work. All he has is ignorance and he seems to be only to happy to share it.
I've been thru tesla, and the truth of growth is that its all DC impulses... the universe is a DC thing... cosntantly moving in a single vector when looked at from any particular point from within this context, while its moving as a Scalar cumulatively and aggregately to grow and take up ever more of the nothing with something...
If you watch those discovery/TLC channel sped up day/night viewings of the rainforest you can see the pulsations of life in the thermal gradients which are what are asymetric (or which are picked up asymetrically by the plants interacting with such) to then allow them to Expand during the day more than they contract during each night, thus evincing a "growth" function...
No need to furnish references for the tesla claims, I've purchased and own most books published relating to Tesla... been thru them a few times too. You might dig looking up a guy named D'arsonval as all of teslas "coils" were setup with biased polar primaries... d'arsonval had a means for making the drive coils unbiased... which I've managed to replicate in a couple novel setups in my garage... the ion chair and the bellerian apparatus.
Curious stuff huh.
Take care,
Gene
Curious stuff huh.
Take care,
Gene
Originally posted by Bob Smith
