  • https://www.webelements.com/iron/crystal_structure.html
    Iron structure
      I am convinced structure is the key to free energy.
      We are trying to find an infinite power source to tap into and i believe that source to be the planets magnetic field.
      A pattern reoccurs over and over in my search its the hexagonal structure and i beleive this to be the geometric organization of the earths magnetic field.
      I think any hexagonal structure of the Earth’s field might have some relation or similarity to Saturn’s well known hexagonal structure at its pole.
      I have doubts that the centre of the Earth is iron, as molten iron won’t be magnetic, or if there is indeed molten iron there, then it isn’t the iron producing the magnetic field.
      It would be stellar electrical currents that give rise to the Earth’s magnetic field.
      Then again if there is iron there, maybe it somehow polarises the electical currents, which in turn give rise to a hexagonal magnetic structure?
      • Tesla said Earth is metallic ball. It's obvious that the synchronicity of Earth rotation even with large influence from big planets is a clue. Earth is not a generator , it's a motor powered by external cosmic current.
        "Throughout space there is energy. Is this energy static or kinetic! If static our hopes are in vain; if kinetic — and this we know it is, for certain — then it is a mere question of time when men will succeed in attaching their machinery to the very wheelwork of nature."
        See ? It's simple. If Earth magnetic field is static as scientist force us to believe then our hopes are in vain.
        • Hubbard was on to something but greed as with most won out, we dont know what we would truly do in that situation. Its best not to get into that position, open source.
          Look at Searls magnetic device and the Hubbard device, one uses permanent magnets ond the other coils but they both have the same geometric layout.
          hubbard did it.
          • I haven't really followed Smith that much. i did attempt a replication but was not successful.
            i am really into the Figuera device and have devoted the last three years to this. the only reason i know so much is because an individual that has a 5 kilowatt working system (1908) shared a lot of information with me. i had a two core jobber that put out 300 watts with 100 in but was not a self runner as i was using resistive wire and had no core which to store inductive kickback from the receding electromagnet. i have since learned a great deal about part G but have stalled in my final build from financial devastation.
            my attempt to pass on this information has failed miserably and resulted in massive flaming on ou and i don't have the energy or the desire to continue this road.
            i know in my heart the figuera device works, even proven by William Hooper 70 years later. how i am going to prove it with no money and half a build i haven't a clue. all i know is the rest of my life will be devoted to the final build and the spread of truth.
            it's not much, maybe not even to cents worth but it is what i believe in.
            MM
            • Current
              Post # 1140, Thread:** Re-Inventing The Wheel-Part1-Clemente_Figuera*
              (Now, I will repeat what I have explained before, Figuera writes on Page 5:* )
              Como se ve en el dibujo la corriente una vez ha hecho su oficio en los diferentes electroimanes vuelve al generador de donde se ha tomado;*
              As it is noted on the drawing, once current has done its job on all the electromagnets returns to generator, where it (current) was taken from;
              This whole sentence above... I find it completely wrong, nonsensical and absurd ...the current, once that it passes through all resistors, then through all electromagnets in his drawing...never, just "returns" back to the generator.
              That specific current, in just a full cycle running through those 13 resistors and 14 electromagnets, never, but I mean never, ever, could just "return back" to generator, like if there were no losses at all..
              In reality, current never "returns", and contrary to that there would be a very high demand from "where it was taken from" (generator, external source)...instead of any return at all.
              One amp would get burnt in a matter of seconds by going through all those resistors and coils in less than a full cycle of that brush!!!
              I've been scolded for disrupting threads by getting after Ufopolitics incorrect and erroneous statements.* So I thought I'd bring this observation over to this thread.
              Ufo claims to be an educated engineer but his statements concerning the way electric current is used up, "burnt", "wasted", and "never returns" in a circuit obviously demonstrates a lack of understanding of very basic principles of electricity on his part.**
              @Ufopolitics:* You need to revisit Basic Electricity Fundamentals.* Circuit analysis and Kirchhoff's Laws for Current and Voltage would be a big help to you; necessary IMO.
              I've seen a lot from Ufo which was difficult to understand (to say the least), but this is unbelievable.**
              Edit *, **, I've been trying to post this all day. Something screwy with the forum or connection. No idea why it stuck in all the *
              • Tooth-Teeth
                Hello Hanon,
                Commutator Bar is just fine, I call it Commutator Element, some people call them Commutator Tooth (Plural, referring to all) or Teeth referring to just one (singular)...other call them Commutator Contacts, etc,etc
                Hi Ufo,
                In English, tooth is singular and the plural is teeth.
                Or are you making your own rule here also?
                  Bistander,
                  I thought that post belong to Citfta...and not from you?
                  Did You forget to change ID Member Names before posting here?
                  Anyways I will answer to Citfta, not to you, since was him who posted the above correction.
                  As you can see I am very "organized"..
                    Hi Ufo,
                    Thanks for correcting me there...I will fix it, do not want to confuse Hanon with my terrible English!!
                    Well, you know that is my weak point...the singular and plurals in the English Language.
                    • Understanding electricity
                      But of course!!...if the Supply keeps up with the Demand of Currents they would be identical.
                      You are talking about a circuit which runs stabilized based on source-demand of currents spending goes...the following example in Automotive below is NOT, so, every time we start our vehicles, the current drop is huge at battery, while voltage drop is just Millivolts and as we run down the car, it re-charges back the battery as it takes over majority of vehicle electrical spending.
                      So, I will put a basic and simple example:
                      Say you have a Diesel Truck, eight cylinders, which have approx about 900- 1200 psi of pressure on each cylinder...you need to "crank it" to start it up, but it do not starts...now your battery may show a full 12V with a regular V meter, NOT a LOADING Battery Meter to check load!!...but at the time to start the starter motor won't do it...it just do not have the "JUICES" which are called Amps, or Currents, Or Intensity to be able to crank those Eight Pistons at 1200 psi each...which means it have exactly the required V but not the amperage to do the job.
                      Say Battery was supposed to have 1200 Cranking Amps...but it only have half...600...so can not do it, unless the guy get a parallel boost or charge it overnight.
                      However, if everything would be fine, the truck driver would turn key and go, start up...at that precise moment of start up the Battery is VOMITING very close to those 1200 Amps, say 900 to 1000. And where did they go?...now tell me they "just" returned "intact" back to battery...because if so...they would never require a whole AND full Battery re-charging system installed "full time" in every vehicle....What did that Heavy Duty Starter Motor cranking those eight cylinders burnt in High Mechanical Torque, plus heat?
                      Did it loose just Volts?...really?
                      Then why this Diesel Truck Alternator needs to be such A BIG HIGH AMPERAGE HOG?...and trying to replace it with a 4 cylinder small VW Golf Alternator will never do that job?...BOTH ALTERNATORS GENERATE 12VOLTS...SO WHY CITFTA?
                      NOPE, I WON'T, I meant exactly what I WROTE,... AMPERAGE, CURRENTS, INTENSITY.
                      And do NOT come here talking about "WATTS"!!
                      Dear Ufopolitics,
                      I read the above quote from you and find your misconceptions and lack of knowledge to be very deep. I feel it is so bad that neither Citfta nor I can be expected to attempt to correct you or educate you on basic electricity. You need professional help. If you wish to continue with electrical apparatus design, research or work of any kind in the field, please enroll in an educational program (school or institute) where they offer a certified program in basic electricity and introductory electronics and maybe further courses in electric machinery.
                      Bistander
                      • LOL!
                        You are not open minded enough, bistander!
                        If you want to create magical apparatus, you should not go to school, not read up on classical physics and not listen to anyone (who you can not understand anyway). Just use your imagination and fantasy and find new uses for old words, talk about vortices (important!), voidance, dimensions, counterspace and spend most of your time elaborating on how wrong established science is and attack all who seem to defend it.
                        You will have to think out of that box (that one containing your brain) and post thousands of post on forums like this showing of your complete incompetence.
                        Then, and only then the muses of electrical engineering will come down and filleth thy ears with insanity which thou shalt speaketh until the end of days.
                        Ernst.
                        • Good one Ernst!!
                          How true you have spoken.
                          I guess every forum has to have at least one. I think we have more than our share.
                          Though sometimes I really feel like this:
                          It does appear that more and more people are starting to catch on to our main attraction though. I see fewer and fewer people standing up for him.
                          Thanks for your insightful comments.
                          Take care,
                          Carroll
                          • Brain Damage
                            Since my time on forums i have realized that some people are really sick in the head. i don't know if they were dropped on their head as a baby, a childhood disease or beat and/or picked on in school.
                            your right about there is one where ever you go but i guess this forum is the breading ground.(consider the source)
                            since i am dealing with this very same issue, i tend to agree with what has been said. most of the time in these cases a mental issue is involved or a traumatic experience (possibly sexual) that changes their personality.
                            it would seem to me that this type of person runs around pointing out other peoples flaws will never look in the mirror at the most flawed of them all. avoidance and redirection of reality is the strategy used by these individuals to sustain a distance from the mirror.
                            to them it is easier to point out ones flaws and mistakes then the reality of facing there own fears while looking at the reflection of the sick person in front of them.
                            while these type people very distracting at times, i still remain strong on my path to the Figuera device. i figure it my destiny to build and spread the truth of this device and NO individual will detour me from that goal no mater how hard they try.
                            MM
                            • Way out there thought
                              Just to bring up previously mentioned earths core,molten?magnetic?metal?
                              what if and this is just a way out there thought what if the earth was really hollow?How would or could that affect the gravity?There is enough evidence to suggest the moon is hollow and yet it has a gravity(not much but its there) and does one revolution around the earth in one day approximately.Suppose we have 100% evidence that the moon is hollow and the earth is not.Yet both have gravity.That we know and have evidence.There is a theory that gravity is a push and not a pull.Now think about that for a moment.If you have 2 magnets facing each other one north side the other south side.You would be in a pull situation.The slightest movement on either on when they are placed apart in position,will cause the pull of both or one of the magnets.Now have opposing poles.They can wobble,vibrate,distort what ever but they do not go shooting away from each other with the same force like the attraction set up.If there were several magnets involved so that they were all pushing each other they would all relatively hold their positions.I think when it gets figured out how to magnetise a ball of steel for example so that the whole outside is one pole and the center is another pole then I think we will have the gravity answer.it seems there is a difference to a magnetic pole and to an electrical pole.Although they have similarities they also must have differences.Anyways just rambling here and would be interested on the thoughts of this one then Ill give u my idea of a speed/brake control for a magnetic motor i thought of.
                              Andre
                              • Happened again
                                Hi all,
                                It has happened again. I ask a few reasonable questions, politely, and Ufo and his fanboy MM request I no longer post on their thread even though neither started the thread. They want no participation except those building or planning to build the device. You know? I might, if I could get some straight answers or encouraging demonstration. But they claim harassment and attack when I have been polite and civil. They cry to admin and claim double identity to distract. Same old thing. They do not want any interference with their BS.
                                Carry on,
                                Originally posted by marathonman View Post
                                It never ceases to amaze me how ignorant people have become.
                                i have devoted my life to the Figuera device and have freely and openly shared my wisdom on this forum just to have it twisted beyond belief and thrown back at my face.
                                normal people would except new technology or information with open arms but not you people, all you do is criticize, ridicule, discredit, break down or twist the information handed to you and bite the hand of the person giving the gift all because your feeble little minds can't comprehend the information being given or it's implications.
                                i am totally ashamed to even call you human as humans in my book are eager to learn and learn from there mistakes.
                                there is probably only one other person that knows more about this device than i do yet you people (the non builders) sit back in your chairs and run your mouths like no tomorrow criticizing my advice. all i can say is get off your lazy asses, close your mouths, open your ears and start building.
                                UFOP is right, i don't want to hear a single word from you people if you are not building or plan on building. cry some where else because we or I am not your baby sitters.
                                if it was not for UFOP i would be long gone and all existence of me and my work with it. i have over 465 followers following my page and i erased every single bit of awesome research i had in my extremely agitated state i am in right now and for this i am sorry.
                                MM
