Hi folks, this radiant charger is working so well and is cheap to make, thought i would start a thread for it.
Has anyone tried this setup.
Hi folks, I am trying different circuits that i see in some of patrick kellys pdfs, etc. and I am having good results with alexkor's air core coil radiant charger.
I made the air core coil (24awg.) with twice as many turns as i should have though and will make another one with the recommended turns.
Using a nte2300 fast switching npn with 1.5kohm base resistor and a .1uf capacitor across base resistor.
I initially was using a nte5817 diode and results were not that great, then i took a couple of salvaged her303 diodes, placed them in series and the charging output increased dramatically, though the input doubled to 250 milliamps, not completely sure why.
Using a 12volt, 7ah input to charge another identical battery, though i will try charging a 48 volt battery bank next, as i think it will charge well with this setup.
The coil is one layer on cardboard tube, like the slayer exciters, so the frequency is probably high.
Here is the circuit from kelly's chapter 6 pdf.
http://free-energy-info.co.uk/Chapter6.pdf
![](http://img849.imageshack.us/img849/4031/alexkoraircorecoilcircu.png)
Uploaded with ImageShack.us
![](http://img692.imageshack.us/img692/4131/alexkorjoulethiefaircor.jpg)
Hi folks, in case anyone is interested, i looked up the specifications for the nte5817 diode i was using, compared to the her303's i am using now as far as max. reverse recovery time.
The nte5817 diode is rated at 2.5us and the her303 is rated at 50ns.
So that is a huge difference in speed, 50 times faster and explains why this air core coil setup is now working so well as alexkor pointed out in his improvement circuit.
And the nte2300 i am using has a max. 400ns fall time, so that helps also.
Your thoughts on this alexkor circuit are appreciated, has anyone built this circuit or intends to as i am very impressed by its performance.
peace love light
tyson
peace love light
tyson
![Sun](http://www.energeticforum.com/core/images/smilies/sun.gif)
