Canadian Gift to the world
GEM =
God’s Electricity Machine
THIS IS A FREE FOR ALL
self generating electricity machine
this is the Canadian Gift to the world
please prove that it does work
in all scales + voltages
Subject: Free energy 4u2
Help me, help others, help themselves
we could start a new + improved industrial age
one that not only cause little mess of pollution
like in the original industrial age brought with it
This one could actually help our environment
by producing costless to run air and water filters
we could possibly have every back yard mechanic
coming out with very specialized adoptions
for this free energy box, cube, machine
I have stumbled upon the
PERPETUAL MOTION machine
Yes,,,,, and even better than perpetual,,,,
,,, this machine actually makes its own power,
as in – this system uses passing time to gain electrical energy,
yessss,,, we can let electricity generate itself,,,,
No more dependency on OIL, and the middle east oil supplies,,,
= and the world says - YES
Now hold on just a moment,,,
I know that this is not a true example of perpetual motion,,,
Because of bearings alone,
or should I say, the fact that they will wear out eventually,
That is why I added the word "machine" afterwards
This is a man made machine,
Which only mimics perpetual motion,
As it continues to run, seemingly forever,
Producing electricity as a side effect, (bonus !!!)
This great invention,,,
is my electric wheelchair,,,,,,,
When I go up + down hills,
I gain more power than I use,,,
As in, a net gain of energy,
After going up and down a steep hill,
I do not know why my Lord has chosen to share this with me, at this time,
Maybe it is because my Father knows that time is short,
and He wants to show all mankind,
just one more way that He is Love,,,
God has shown me,
a way of gaining free energy,
seemingly from nothing,
This came to me when I was over visiting at the park,
I was thinking about how electricity worked,
and how my electric chair had the ability to charge itself,
on most any type of downhill run,
(as it uses an electrical breaking system)
I don't know if you know anything about me or not,
but learning new things is one of my greatest pleasures
and,,,,
When investigating how things work,,,
I always have to push the limits,,, lol
not only learning how things works,
but then tinker with trying to improve them,,,,, lol
I went with the idea of a ten speed bicycle, (something that I knew about)
Where I wanted to go uphill in tenth gear, (least rotations of the pedals)=motor
and then downhill in first gear, (most rotations of pedals)=motor
so, I would go uphill at full speed,
and then downhill at slow speed
So,,, now I had something to experiment with,
now I had measurable tests to do,
I started off with a low battery, (so that I did not have the power to drive all the way up)
driving up a long steep hill at the park in the full speed position, (tenth gear)
(until my chair would not go any further, as my battery was dead)
and then going back down the hill in slow speed, (first gear)
(not super slow, as I had time limits = only 4-6 hours of sunlight left)
Then I immediately turned around, and went back up at full speed,
And guess what happened,,,,
I could travel twenty feet higher up the hill,
so, I had a net gain of electricity,,, (a blessing)
Logic and common sense says,
that you will have energy losses,
do to heat from friction if nothing else,
causing you to not be able to make it as far up the hill,
the second time you drive up it,
Well, I first thought that this might just be a strange happening,
so I did it again and again, doing it three times,
each time gaining twenty more feet, up a steep hill, (60 feet total)
Not only did I do it three times that day,
but I later thought that this went against logic, (I must have dreamed it)
and I did the whole experiment over,
with the same electricity gaining results
I know that there are inner workings of the motor + drive system,
that I have not even roughly looked into,
to find out why + how it works like a 10 speed,
Sorry, but I have no time to color + shade in this drawing,
I could only give you this rough sketch,
and let others get the enjoyment of coloring in the details,
may this bring you at least some of the thrills that I have experien-ced,
when I was showed this amazing reasoning,
Please read (Luke 18:29-30)
Someone could easily build a self supplying energy producing power supply,
With a 12v battery,(not needed) two motors, a small and large pulley, and a belt,
You connect the motor with the big pulley up as a power in, driver motor,
And then connect the motor,(s) with the small pulley to be used as an output
When you put power into the drive motor,
You get out a multiple of this power, (on each of the out generators)
Compared to the size difference of the drive motor, (large pulley)
And your output or generator motor. (small pulley)
--- (after thought) ---
I feel bad,,, about being so sluggish,
Wishing that I could have spoken of these things earlier,
as in, as soon as it came to me, a few years ago,
(I had a hard time wondering why this was not discovered earlier)
((I guess that we are waiting on His Timing))
(((as nobody seems to be listening to my logic)))
((((nobody has built one for me yet, to prove me wrong)))
NOW
Please,,, send this to everybody you know,,, so that we can have more people working on ways to utilize this new use for old technology,,,, after all, more is usually better,,,,,,,,
believe me,,, I know how unbelievable this sounds
I had to repeat the experiment three times
to get a better understanding of how to believe what I was seeing
and then I even thought that I must have dreamed it
and had to repeat the exercise the three times again, about a week later
Perpetual Motion machine
That's right, I will tell you how anyone can get electricity to generate itself, without having to own nor having to be contained in an electric wheelchair,,, lol.
I say this because it was my electric wheelchair that helped me think of, and prove to myself that this idea really works. I was in a wheelchair because of an automobile accident, where I was not only paralysed, but I found out that I was the recipient of a rather severe closed head injury. I woke up six months later, to find myself paralysed, with one bum left arm and hand, and unable to talk. I had to first relearn how to speak, to be able to ask what had happened to me, as not only had I lost most all my short term memory, but I could not remember. as well as many other things, like
Just think of it, We could all have our own stand alone, self powering electricity generators, with only the initial cost of building it,(could be made of junkyard parts). These power manufacturers could be producing a seemingly endless supply of free electricity, all for the cost of upkeep. It is easy enough to build, as all you need is a twelve volt battery, two 12 Volt motors,(one DC + one AC) one large pulley, and at least one small pulley, a belt that fits the pulleys, and the hardware to put these parts together.(nuts + bolts + framing to mount on). This could even be done with 120 volt motors, to produce power for yourself, or to use as an income when you sell it back to the power company.
((along with electronics, such as an AC and a DC motor, a battery=(not needed), wires, a bridge rectifier and a voltage regulator, of equal voltage))
((all of the electronics to run this could be easily built on a simple proto-board))
(you might even be able to use any voltage motors - even 120 Volt)
((taking your output from the ac motor leads))
(((as I don’t think the battery is a necessary component)))
It is a very simple mechanism in its workings, as it works by putting power into the motor with the big pulley attached, and you take power out from the motor-(generator) with the small pulley attached. The output motor, or several motors even, the one(s) with the small pulley attached, rotates a lot faster than your input motor,(more speed = increase in power). There is a belt connecting the two,(or more) motors together, that can be as small as you want, depending on if you required size constraints, or as large as you want, to accommodate multiple output generators,,, like in our petrol fuelled power stations, they could be easily modified to run on their own power. I cannot be sure, without having results from tests, but I think that we can gain more power, with every output generator that you add with a small pulley. But there is a warning that I have to give you, of a possible hazardous flaw in this free electricity generating system.
CAUTON,,,,,,,,,,
If this system is allowed to run freely,
without having any outside drain of power,
this system will overcharge itself,
and may even explode.
So, please,,,
be careful when experimenting with this mechanism.
Maybe this should be called an Energy Multiplier,
as you always need at least a little power,
to generate the greater amount of power.
GEM =
God has shown me,
and,,,,
NOW
CAUTON,,,,,,,,,,
So, please,,,
