Originally posted by thx1138
I am one who writes that neither perpetual motion, nor ZPE, exist.
However.
The energies stored within atomic nucleii, or their *already energised* orbiting electrons (little gyroscopes) CAN be transduced if that energy is released,
especially when atoms are in a matrix pattern such that their co-axially aligned electron spin-orbits constitute an induced or 'permanent' magnetic field pattern about the body of matter they are a physically component of.
That electron orbit aligned permanent magnet field may be used to induce a secondary electron orbit alignment within a nearby conductor or completely separate soft-iron-steel body.
Conventional COP<1 alternator-generator-motor arrangements are via coil cores and/or winding arrangements which relate to *SINGLE* magnetic circuits of stator-magnet field-line cutting motion.
However, Lester Hendershot's and Wesley Gary's buzzer like armature relationships relate to isolated core induction relationships from *BOTH* poles of a single horseshoe magnet, and a longitudinal solenoidal overwind related to that core.
(Lester's overwound component is the pair of ringer cores.)
As I asked earlier;- Why are horse-shoe shaped neodimium magnets not available ?
Well both of these gentlemen would have been able to answer that question *85* and *135* years ago respectively; for they could both have made excellent use of same.
Neither Lester nor Wesley needed our modern ‘science’ and ‘maths’ education to understand the intermediate capacitor-like storage effect within a soft iron/ steel core which their own *hands-on* investigations so clearly demonstrated.
Where a permanent magnet can induce electron orbit re-alignment magnetism within a nearby iron core,
the associated field within the core may be 'discharge' transduced or alternated via some mechanically cycling or electro-mechanical arrangement,
into a continuously alternating electrical supply,
this being due to the nature of soft iron itself, plus some steels,
BUT where,
at some critical distance between the magnet and core,
a slight alternation of mechanical or field coupling from both poles of the permanent magnet,
or the coil's mechanical core or field coupling with respect to a fixed bipolar field source,
the induced field coupling within the core will suddenly alternate between series and parallel induction, (or parallel-series)
as if by itself,
with electron orbit alignment reversals (precessions) within the core,
representing two transducible Schmitt trigger like energetic output pulses,
for just one unipolar half cycle of electrical or mechanical input energisation.
Both Lester Hendershot and Wesley Gary generated electrical output without claiming perpetual motion, for both clarified that their magnets were not permanent and would need recharging (neodimiums!), and both knew that it was the oscillating magnetic arrangements which generated their energy, not ZPE.
Hence one old drawing relating to the 'Hendershot Magnetronic Generator', and here I have been discussing the buzzer cores only, not the twin induced core-cap reactivities.
Cheers .............. Graham.
