Originally posted by pjotterkjen
The ring magnets that I have are 2 3/4" x 1 1/4" x 1/2" not big enough, the ID is a little narrow. The only reason I have not placed a ring magnet inside coil a/b is because I am have a mental problem with the weight of those magnets. The size your suggesting will almost consume the entire space within the coils. I build a/b in a basket weave (not honeycomb) and combined them on the same form (both coils interleaved together) with a 3" dia. it leaves no room for any ring magnet.
However, if coil a/b were 2 separate coils, one inside the other the height would be 1/2 the size and the combined coil could sit on the ring magnet. One of the combinations of coil design was to make the dual coil in a basket weave layer but honeycomb together to overlap the field that could be generated. There are just so many things to try.
I am still not sure about the ring magnet on the MK1. At the air force base where the construction was be made the MK2 was the model. Besides the new coils within coil a/b all the other parts were the same as MK1. We are still missing something. The 3" dia coil a/b that I made is only 2" in height, your ring magnet would be taller than the coil. I don't need to copy the MK1/2 I want to understand and just make something work. If the ring magnet will do the trick I am good with that.
