Hi folks, gadgetmall found this circuit and posted in other forum.
Was looking for something to do, while the SSG charges batteries, so whipped up this circuit with a transformer had already rewound with bifilar 24awg. primary and 30awg. secondary, works well for 12 volt input.
Used salvaged 2 amp 1watt small PNP transistors, though larger 2n3055's NPN can be used also and 10kohm resistors were used.
It can power this 3 watt RGB led color changing bulb no problem and when lowering resistor values to 4.7kohm, can power a 5 cd changer/radio boombox that says 25 watts input, though this inverter only draws around 9 watts with it and the transistors barely get warm, which seems odd.
Just thought would share, since it has such low part count and works real well. Normally these use capacitors also in oscillator stage, this doesn't, it uses the coils capacitance instead to perform the same function.
The bifilar coil is used in my setup and for the center tap connection, the end of the first primary strand is connected to the beginning of the second primary strand.
Here is circuit, site calls it a micro inverter and pics of me setup.
Uploaded with ImageShack.us
peace love light
tyson
peace love light
tyson
