Hi folks, Hi dave, thanks for the reply and information.
Watched both videos where woopy was melting stuff and the other lighting a 3 watt led bulb.
Looks like he was NOT using the diodes when lighting the led bulb, though have a medium size iron toroid here that can be rewound with the sergdo winding scheme and see how it works out.
Will probably make a winding turns ratio for 120 volt loads, like cfl's and such.
Not sure how the current is trailing the voltage, is it because the red primary shown in that image is closer to the other secondary winding or just because one of the secondaries is connected to the beginning of the other, thanks for any explanation.
Hi nick, thanks for the reply and kind words.
Yes turns ratio and wire gauge does seem to matter, it does ring a bit.
This is using the mosfet as the power transistor.
Tried the other iron toroid that was made for the JR3.0 with this mosfet pulsing circuit and lights the 13 watt brighter and at less input amps than the ferrite bead core, though the primary wire gauge is higher, 24 awg. and less 30 awg. turns, so probably more proper turns ratio.
If you have any mosfets and couple of NPN bipolar transistors laying around nick, you should try this pulser circuit, it seems to work well.
Using 224K non-polarized capacitors from R.S., instead of the 2.2uf ones.
Mosfet is a salvaged, FQP45n03L, rated at 45A, 30 volt, 180A pulsed, 75W.
peace love light
tyson
peace love light
tyson
