You would be better off just scrapping the trigger wire and going with somthing like a Fixed Frequency Crystal Oscillator.
Also those 3055's are just dated. They are good transistor but for higher speeds with the same SOA curve use a NJW21194G. Its the Direct replacement for an MJL 21194 at way lower price. Lower resistance
The crystal will hook between the 10k resistors (Which can be turned down to 1k if needed) to the base.
If your going to wind it with the trigger make sure to run the numbers and get the frequency up to around 40khz. Your going to be able to use less power and be more efficient.
If your curious do search on Florescent light Power frequencies, or the Lighting research center. Lots of info on what make a florescent tick.
I got parts coming for setup I got in mind, so hopefully I a can stop talking and start showing.
![Thumbs Up Smiley](http://www.energeticforum.com/core/images/smilies/thumbsup.gif)
