@ Bro Mikey only...
Hello Bro Mikey!!
I will come to your rescue (like most of times uh?)...
Electric Engineer Clemente Figuera had a "Vision"...after carefully observing how electric generators operate while running...He visualized what Virtual Magnetic Fields were -basically- doing by rotating within the induced coils...then came to a very logical conclusion...
That looking from the point of view from the Induced Electromagnets...all the Virtual Magnetic Field was doing....was getting closer to fully alignment engagement, full magnetization... to then fade away...and so this Cycle will repeat over and over through time...
So, he thought of the possibility to "Mimic" this Virtual Magnetic Field Operation...by fluctuating the currents which feed electromagnets...but electromagnets (Exciters) being Static...and so also the already Static Induced Electromagnets...so the "plan" was just to fluctuate the Virtual Field Spatially back and forth...
The Figuera Machine shown in the 1908 Patent (his final work after his sudden and unexpected death weeks after patent publication, as signing some sort of "deal" with Bankers...) was His Final design...
Figuera Mimics the close and far virtual fields by making the static electromagnets weaker then stronger by Currents Fluctuations through time.
This is done without allowing Field to collapse (field flat line at zero) nor go negative (reverse)...just because these two options (collapse or reverse) never take place in any existing and operational generator up to now..
So, this is it...Figuera was very different from all the rest...even up to now...since He had the Capability to see in the Invisible...the Non Physical, Massless, weightless therefore Non Physical Magnetic Field...completely and independently observation... from any Material Magnetic Carrier...the electromagnet...not like Classic Magnetism has dedicated the last two centuries to study just these Material Iron Cores...by sprinkling even more iron on top...in dust shape...
Some people are not even able to see even the material things taking place around them...just because their very low ability of observation, much less of analysis...so then imagine...how could they possibly be able to see in the invisible?
Bright minds are able to see there, where those retards can't...observe carefully...then conclude...then innovate...then invent.
It should be very obvious to deduct that moving a weightless, massless field that can go through every single mass on planet effortlessly...will cost very cheap to do...while obtaining huge amounts of Induced Energy (Figuera Machine was conceived for Industrial Production)
Hope you could understand now Figuera main purpose and achievement.
Now, to fluctuate currents he is using a simple and Elementary Example...a row of resistors on Patent, as an easier form of understanding currents fluctuations in his specific fashion...then we will get into the going on arguments here and on other thread...about the "means" to achieve currents fluctuations...
And the way I understand the word "Example"...is that there are more than one possibility to achieve Main task...right?
However, the main, basic and interesting idea where the whole thing revolves around...is all written above.
Regards Friend, and so I hope you get involved in building it later on...
Hello Bro Mikey!!
