  • bistander
    Originally posted by Rakarskiy View Post
    ... My material summarizes the results of my research that I shared with.
    Then it should be easy for you to answer.
    Does this method provide power output in excess of input power?
    Edit:
    is this your conclusion?
    "...synchronous generator with a solid-state rotor (without mechanical rotation) has been patented and implemented in the USA. Holcomb Energy System . This device is direct proof ..."
    quote is from your material.
    Holcomb's "proof" is false.
  • bistander
    Good afternoon, try doing the calculation. Suppose we have an oscillator phase nested in two magnetic closed circuits in which we vary the vector and saturation of the magnetic intensity by two electromagnets controlled through a resistive regulator according to the scheme proposed in the Figuer patent of 1908. The flux excitation should be calculated as for an electromagnet, and the EMF excitation in the phase (output winding) as for a generator.
    This is very easy to check first mathematically, then practically, just by using two identical matching cores, the only thing you need is to make an appropriate small gap (0,3-0,5 mm).
    This has not been practically tested, only calculated. If you have the resource, you can test this on a real device by pre-designing the control circuit.
    Hi Rakarskiy,
    do you think that is an answer to my question?
  • Rakarskiy
  • bistander
    Hi, bistander! The conclusion is based on the principle of electromagnetic induction in electromagnetic generators with cores and the operation of transformers.
    In the figure is a slice of a Dynamo with an armature that rotates for which position in the wire laid in the slot, will be the maximum EMF (A-A' or B-B').
    Your Electricity * Over Unity: Invention of the Electromagnetic Generator (rakatskiy-blogspot-com.translate.goog)
    Hi Rakarskiy,
    thanks for the reply. But you must have overlooked my questions. So here is a replay.
    What is your conclusion?
    Please answer.
    Thanks.
  • Rakarskiy
  • bistander
    Hi Mr. Rakarskiy,
    Nice to hear from you. Thanks for relating your new article.
    If so, provide proof.
  • Rakarskiy
    Completed my research, corrected an error (in my opinion) in the topology of the research document that started this thread.
  • bistander
    Hello to All,
    Due to the sudden shut down of Overunity.com, where I was going to expose my New Method about Figuera Patent from 1908...
    I have decided to open a New Forum, based on the same software as overunity.com was based on (SMF), except, I am using its latest version.
    OVERUNITY MACHINES
    I invite ALL BUILDERS HERE, that are willing to Replicate Figuera, but, this time giving excellent results.
    Hi. Ufo,
    I'm glad you posted this here. Why not just use this forum? Why start your own? I know, so you're in control.
    I look at the terms and conditions statement for OVERUNITY MACHINES and see this.
    "You agree, through your use of this forum, that you will not post any material which is false, defamatory, inaccurate, abusive, ...."
    Isn't the name of the forum false? There is no overunity machine. Isn't the term "overunity machine" inaccurate?
    When you, UfoPolitics, have control of the conversation, you dictate your viewpoint. And your viewpoint is often wrong, false, mistaken, inaccurate, misleading and objectionable to anyone properly schooled in the subject matter and knowledgeable in science. I have experienced this on numerous occasions with you deleting my messages and posts. I find this rude, to say the least. That's why I don't post on threads for which you have moderation control. And why I don't intend to join your forum, unless you can guarantee that I will never have a single word deleted or changed without my prior permission.
    Also, back to the terms and conditions, history on this forum shows numerous instances where you have been defamatory and abusive to me and others. Not so much recently. I hope that continues.
    Anyway, here's hoping you find an open, free speech forum. Good luck.
    ps.
    You're always welcome to contact me, in a friendly manner, via PM on this forum or OURdotcom.
  • Ufopolitics
    Hello to All,
    OVERUNITY MACHINES
  • Ufopolitics
  • Rakarskiy
    I also worked with a similar principle and dismantled Figueras. I think my little investigation will be useful to you
    Your Electricity * Over Unity: GENERATORS CLEMENTE FIGUERA 1902 (rakatskiy-blogspot-com.translate.goog)
  • norman6538
    Since posting new stuff on overuntiy.com has been halted I hope we can continue that discussion here. UFOPOLITICS posted some new work and will continue that on youtube ...
    Norman
  • hanon1492
    Very important post and attachment (Egg.pdf) by user "Fernandez" in another forum (OU dot com) on the 22nd of november
    It agrees totally with Figuera´s design:
    https://overunity.com/14906/joseph-h...846/#msg571846
    I attach here his document (Egg.pdf). "The Egg of Columbus"
    Egg.pdf
  • hanon1492
    Hi,
    You would find some amazing coincidences between these patents and the Figuera configuration:
    US4904926 https://patents.google.com/patent/US4904926A/en especially figure 5
    WO2009065219 https://patents.google.com/patent/WO2009065219A1/en especially figures 1 and 2 and paragraphs 27 and 28 where polarity is defined
  • seaad
    @ Grey Wolf
    Is it possible to send a a wiring drawing (showing min. one phase /commutator principle and the DC feedback)
    and some sketches to clarify the last part from this quote;
    "Contrary to the popular opinion that the primaries need to be N to N, even given the fact that that arrangement will give higher voltage, ALL of the sine wave curve is above the zero plane and there is no sine wave in the negative. Therefore it MUST be set N to S at the top of the primaries and S to N on the bottom."
    See also:
    https://overunity.com/12794/re-inven...025/#msg533025
    Regards Arne
