  • seaad
    Thanks Arne,
    From reading post by Doug it is obvious that he has misconceptions about magnetic influence of flat wire although he doesn't mention inductance.
    Exact! How about the/ a magnetic field then? I don't know such. I have to do some tests and let mother nature help me out.
    Regards Arne A
    P.S Just saying: REEL How important? And PROPERLY PLACED?
  • bistander
    Originally posted by seaad View Post
    I have pics today: First two a toroid G-part with CW and CCW windings on. With is functional. That is still a continuous winding!
    The other two pics shows another type mentioned by Doug.
    And I found a thread from Doug1 describing flat wire (last part). Maybe it is from this MM got his ideas about flat wires?
    Re-Inventing The Wheel-Part1-Clemente_Figuera-THE INFINITE ENERGY MACHINE
    Regards Arne
    Thanks Arne,
    Yes, if you recall I proposed the half CW half CCW winding on the toroid when you and I discovered the continuous (in one direction) winding had serious issues. This is what I was trying to find out. Did Doug use something like this or otherwise different? It would be so nice to get factual information from MM or Doug. They talk about teamwork but fail to follow through.
    From reading post by Doug it is obvious that he has misconceptions about magnetic influence of flat wire although he doesn't mention inductance. MM had all the inductance related reasons concerning flat wire backwards. For the size and power level we're dealing with at this time, flat wire is not helpful.
  • seaad
    G-part again
    Regards Arne
  • bistander
    Another insult
    Originally posted by marathonman View Post
    I tried to explain Many, many things to you people
    No, you do not address my questions. You rant, preach, insult, belittle and avoid any reasonable discussion or exchange of ideas or facts. Explaining something which is on topic is a foreign concept to you.
    I insulted no one
    Insults are better defined by the recipient. I took your comment as an insult.
    what a bunch of fools
    I also take that as an insult.
    I read you recent manifesto on the forbidden thread. You make yourself out to be a messenger or prophet sent to save the lowly human race by means of delivering the almighty Figuera idol. All need to bow down and follow unquestioningly your writings. Only those true believers chosen and blessed by you shall be allowed to enter word into the forbidden thread else they be stricken down by the angel of admin.
    Do you think Mr. Figuera would approve of your command and guidance of this cult bearing his name? You could do so much better if you only understood fundamentals of electricity and magnetism. Composition, grammar and spelling wouldn't hurt either.
  • marathonman
    Your wrong
    I insulted no one but only like the guy that does fly by's and says nothing, slickdick. so when you figure out what he is then you will know.
    I tried to explain Many, many things to you people but you have your head to far up Dogma's back side to listen and are completely closed minded.
    Good cifta does that mean your going to finally shut your big closed minded, i'm stuck in a box trap.
    you people are a total waste of everyone's time and i will not try explain crap to you any more.
    what a bunch of fools running your mouth with no build. what did you people EVER build.....NOTHING.
    show us your build cifta, bistander.... tha'ts right you don't have ANY build but the foam on your lips from running it 24-7 since i started sharing.
    You people on this thread are pathetic.
    From a member on this forum;
    "Citfta and Bistander are way too much blocked by all this classic BS...to the point it really blocks their power of deep analysis which needs to go beyond...but unfortunately there are many, I mean many Citftas and Bistanders all over our planet."
    and this is the general feeling of most that pm me and i get a lot of pm's.
    See ya ! i'm done esplanin lucy.
    MM
  • citfta
    The only reason to answer a person with insults is because a person is incapable of actually having a technical discussion. And denying clear evidence of something is a form of delusion. My last post for a project that has no hope of succeeding with such inept leadership. I will not waste any more time trying to correct all the mistaken ideas being presented here.
  • bistander
    Back to insults
    You know, your a real SLICKDICK.
    MM
    Hi MM,
    You talking to me? Back to name calling? What is wrong with my request for more information? Got something to hide?
  • marathonman
    Something else
    MM
  • bistander
    My post #2073
    I received a PM from MM in response to my post #2073. I wish he'd keep all discussion on the open forum. He didn't disclose anything to which hasn't appeared on the forum. But simply told me Doug built his part G with a continuous winding and has been running for 2.5 years at 5 kW. We've heard that before.
    MM,
    Show me. He must be doing something different with the winding, connections or operation of which we are unaware. Also, two and a half years is about 22,000 hours. Has it been running continually? Has any maintenance been required? Please give us more details.
  • marathonman
    No Resonance
    The Figuera system is not a Resonance system so Mr Seaad gets a star on his forehead. adding what Cornboy has stated that a spark of any kind contains all frequencies it could be that that specific protracted frequency is keying in on his components used aligning the impedances of the system causing a output spike in that region. Resonance was not considered or calculating factor in Doug's 5 kilowatt device nor did it have any baring on performance.
    "BUT" this is an interesting anomaly and probably should warrant further investigation, that much i do agree on.
    MM
  • seaad
    Resonance
    It's not certain it is resonance at all. It just can be a frequency range with have the best impedance match and best operating functions with actual components. Somewhere you always find a protracted peak. In many of my tests 4-6kHz / Arne
  • bistander
    Thanks Carroll.
  • citfta
    Hello Bi,
    That certainly sounds like resonance at work to me. In the days when I used to build my own ham radio equipment after you got it all assembled you had to go back and tune each transformer that coupled the signal from one stage to the next in order to get the maximum signal passed to the next stage. A resonant circuit will respond best to a certain frequency. So we tune the circuit to respond to the frequency we want.
    In the case you quoted the circuit is responding best to a certain frequency range so that shows it is a resonant circuit at that frequency. As we increase the Q of the circuit that will narrow the range of response.
    Another reason I am thinking it is a resonant circuit is that if the Figuera circuit works like MM keeps claiming, is because he insists the power will bounce back and forth between part G and the primary coils with low additional input. That describes a parallel resonant circuit to a tee. But he is claiming resonance has nothing to do with it. Doesn't make sense to me to describe a resonant circuit and then deny the resonance.
    That was a good question. I hope my answer has explained my thoughts about resonance
    Respectfully to all, even to those that want to deny basic electronic theory,
    Carroll
  • bistander
    Resonance
    I knew you couldn't give a technical reason why inductance was important but resonance wasn't. ...
    Hi citfta,
    I'll paste in a copy of a forbidden thread post from Netica describing system behavior he sees with his test. I was curious if you thought it sounded like resonance might be at play.
    Originally posted by Netica View Post
    One thing I have found with my set up at least up to now is that there seems to be an optimum hertz to use, roughly being around 40 to 55hertz. My secondary power output peeks in this area.
    netica
  • SlickDick
    The only reason Solar is allowed is they are not a direct threat to petrol companies due to their inefficiency and your so called fuels of choice all involve petroleum products.
    There is a whole world outside the US. For most American conspiracy theorist this is a hard concept to grasp.
    In Europe, Germany generated electricity especially, is sold on the open market for a negative price at times, due to the surplus of wind and solar power. This will happen more and more in the future. In fact, if Germany did'nt shut down some of their nuclear power plants, electricity would be free already. Only pay for network and transport.
    But hey... Total control you say
    So yes. Lets drop the conspiracy. And while we're at it. Also drop the scientific lies. Science is not static. Current science is aware there are errors in some theories used. New errors are found on a daily basis. If some 100 year old textbook contains a flaw or error, maybe time to buy new book instead of keep on bickering about it.
