Where is my apology
HANON;
You owe me an apology for your insult to me. retract your post or be a man and APOLOGIZE. which ever you choose just DO IT.
UFOP;
Quote; "Resistance "R" is represented on drawing on its elementary form...to ease understanding of the whole system."
This tells me that while it does have resistance, ( being resistors are its elementary form ) it is a higher form then resistors. so what form higher than resistors comes to mind.
magnetics, the only other way to change currant intensity in figuera's time was through magnetic field manipulation. while not widely used at the time never the less it was used.
if you reconstruct the device with the clues in the patent it will be as was stated in this thread.
one end of the resistance to set N the other to set S, commutator bars, why would you have thick bars connected with thin wires.?? that is completely absurd to do that.
Quote;
"Let be “R” a resistance that is drawn in an elementary manner to facilitate the comprehension of the entire system, and “+” and “-” the excitatory current which is taken from an external and foreigner generator. The different pieces of the resistance will connect, as seen in the drawing, with the commutator bars embedded in a cylinder of insulating material that does not move; but around it, and always in contact with more than one contact, rotates a brush “O”, which carries the foreign current, revolves. One of the ends of the resistance is connected with electromagnets N, and the other with electromagnets S, half of the terminals of the resistance pieces go to the half of the commutator bars of the cylinder and the other half of these commutator bars are directly connected to the firsts."
"The different pieces of the resistance will connect, as seen in the drawing, with the commutator bars embedded in a cylinder of insulating material that does not move; but around it, and always in contact with more than one contact, rotates a brush"
does this not tell you people that the pieces of resistance are actually wire wrapped around a core then secured and a rotating brush makes contact to those winding's as it rotates.
remember also the wording of the patent is directly correlated to the elementary form NOT the higher form we have been pursuing.
use your brain god gave you, the patent is describing the device in it's elementary form, plain and simple.
"Concluding, I fully support Marathonman idea and superb visualization of that part G as being more than a merely "CURRENT DISTRIBUTOR" BUT ALSO a RECYCLABLE DEVICE for ALL Currents utilized on this "Machine"."
I'm glad someone finally pulled their head out their back side and used it for what it's for, (thinking) not just a hat rack or bobble head. close minded thinking has close minded ideas.
THANK YOU UFOP BY THE WAY.
MM
HANON;
UFOP;
Quote;
MM
