Many thanks
Thank you Hanon.
MM
About William J. Hooper, MM is right on the spot. William J. Hooper is a good place to start watching anomalies in the current theory. Basically Hooper found that the electric field generated in transformers ( E = -dB/dt ) was of different nature to the motional electric field generated in generator ( E = v·B ). I have said that this generator do not use the principles of a common transformer but it moves the lines as common generators (flux cutting induction)... And this is the real core of this device!!
A good intro here: Frances Gibson: The All-Electric Motional Field Generator & Its Potential (Dr. William J. Hooper)
And Hooper was a scientist... so Bistander, it is a opportunity for you to start seeing something against current theory...
In his manuscript, New Horizons in Electric, Magnetic, and Gravitational Field Theory, Dr. Hooper defines three electric field with distinct characteristics: the electrostatic, which is very familiar, the transformer electric field, which is produced by a changing magnetic field intensity; and the motionally induced electric field, which is the product of relative motion between a conductor and a magnetic field. A table on page 15 of his book shows the major differences in the properties of these fields.
Defensive
Bistander;
Why are you always so defensive as we are part of the human race and there fore on the same side.
and please don't play coy with me as i am in no mood for your BS. you have been on my profile page many times so please save me the drama in front of everyone. i am on this site to help people not the other way around.
if you choose to act the way you are now i could care less whether you EVER get the Figuera device but if you act reasonable then maybe, just maybe you will have a chance to understand the Figuera device.
the choice is yours. good luck because you will need it.
Elcheapo;
I have no concern when it comes to you, i just stated Scientific facts. whether you heed or understand them is entirely up to you.
Have a blessed day.
MMLast edited by marathonman; 12-14-2016, 10:53 PM.
bistander,
a voltage-controlled MOSFET is a switching device
above saturation, which also applies to bjt's.
A transistors main function, whether fet or bjt is for amplification.
The audio circuits where fets are used, would never be able to
function if they were only switches!
MM,
the drop is ABOVE 50% NO LESS
to prove it.
Just a matter of tweaking a couple of mini-pots on my control unit
to get the low above 50%, 60%, what ever.
Thanks for your concern anyway.
Elcheapo
Not much of an answer
Originally posted by marathonman View PostAnd i understand that.
Study William Hooper and the answer will come to you. and i know darn well you know what E Field stands for but in case you don't you should of read the side notes on the pic.
to much detail is being overlooked, stop skimming through and actually study for a change. your bulb just might light up, ALL OF YOU.
E-2 is double the E field intensity and B fields actually don't cancel out as it is just our measuring equipment registers Zero but in all actuality it is very active. his equation may be questionable but his research is not as it is Figuera all day long.
i have the William Hooper paper in my profile page photo albums.
Please enjoy,
MM
I have no idea what or where a profile page is and don't see why I am directed to go there when I just asked you to clarify a few items which you claim are scientific fact. And you do not know what I know so don't tell me that. Why don't you tell what V2 is and how it disappears from the equation or don't you know? And somehow you are claiming equipment readings for math and theory discrepancies? How can that be?
Equations
Please enjoy,
MMLast edited by marathonman; 12-14-2016, 07:15 PM.
Math questions
Originally posted by marathonman View Post...
MM
Would you (or anybody) please explain the math to the left of the diagram? For instance:
E = 2, Two what? 2 Volts? 2 meters? 2 of anything?
Why does B = 0? There are two (or is it 4) B's shown on the diagram. Assuming B is a magnitude of a magnetic field resulting from a primary coil (electromagnet), Ufo keeps telling us it never sees zero value.
The vector equation makes no sense. How can V2 just drop out? And what exactly do V1, V2, and B1 represent as these do no show on the diagram and are not defined?
Please answer my questions as you state these things are facts. I am just asking simple straight forward questions about the statement (diagram and equation), and I am in no way attacking or insulting you. So please respect that and not insult or ignore me.
bistander
mosfet
Originally posted by Elcheapo View Post...
Wrong.
A fet is a linear device that once past the gate threshold (4 volts) the current output is in direct proporation to the base voltage.
Elcheapo... a voltage-controlled MOSFET is a switching device driven by a channel at the semiconductor’s surface due to the field effect produced by the voltage applied to the gate electrode, which is isolated from the semiconductor surface. Because the required gate current during switching transient, as well as the on and off states, is small; the drive circuit design is simpler and less expensive.
AN-9010
MOSFET Basics
To learn more about ON Semiconductor, please visit website at
www.onsemi.com
Reduction
Quote:
"the drop is ABOVE 50% NO LESS on the Low Primary, IF NOT, the too low driven primary will loose magnetic pressure, and the High will be PREVAILING, creating a "rushed advance" over the low one, then Induction will collapse."
Quote;
"The patent mentions nothing of this. This is pure speculation."
Sorry but you are completely incorrect. sure the patent doesn't mention this as that would give his device operation away and everyone that read the patent and ACTUALLY STUDIED IT for any reasonable time would know Figuera was very cautious in his wording exposing just enough to get the patent.
it is not speculation or fairy tale but FACT. if the pressure between the primaries is not maintained the induction will fall to the peak of the rising electromagnet or if unison is not maintained. that means the induction will fall to 50 % output so sorry buddy this is FACT whether you think it is or not. that is your downfall not ours.
if you would have done proper research you would have found this to be absolutely true, no speculation involved but hard scientific FACT.
Two opposing electromagnets in unison, one taken up the other taken down will have their induced in the same direction FACT NOT SPECULATION thus being in the same direction a duel or rather a very large E field will form causing twice the output of one electromagnet a lone FACT NOT SPECULATION.
if the reduction is taken down to far the pressure between them will drop and induction will fall to the peak of the rising electromagnet FACT NOT SPECULATION.
no arguments, no name calling just SCIENTIFIC FACT, NOT SPECULATION.
BELOW IS SCIENTIFIC FACT, NOT SPECULATION.
and if you are not experiencing these SCIENTIFIC FACTS with your timing circuit then maybe you might want to rethink your approach. if you so choose to ignore these SCIENTIFIC FACTS you will be left in the dark paying someone else to power your house.
Quote;
"But marathonman should have all our appreciation to his idea about the use of inductance as current limiter!"
thank you seaad, that was very gentlemanly of you but was actually Doug's original idea as i am just the messenger. a lot of people could never understand him but i could so here i am delivering the message. whether all receives the message and understands it is entirely up to all of you.
all have a great blessed day.
MMLast edited by marathonman; 12-14-2016, 05:23 PM.
Originally posted by Elcheapo View PostThe system of using coils instead of resistors as Satchid posted 5 years ago.
Elcheapo
L+R = inductance plus (with) its internal wiring resistance.
http://www.energeticforum.com/293642-post1342.html
Re-Inventing The Wheel-Part1-Clemente_Figuera-THE INFINITE ENERGY MACHINELast edited by seaad; 12-14-2016, 11:21 AM.
To UFO,
First, NPN will not work, this is about switching the HIGH SIDE, meaning Positive, N-CHANEL FET's will pulse negative (LOW) Side.
Need PNP FET's, High Side, P-Chanel.
To connect the coils like in the patent just ground one end and connect the other to the source.The Drain will go to B+.
This will be same as an emitter foiiower circuit using BJT's.
Using pnp's will require negative going pulses.
and may need a block of FET;s per step.
I'll soon be posting a schematic circuit to clear things up.
FET's are just electronic Switching relays, meaning either ON or OFF, period.
only current will NOT do it alone
Magnetic field strength is directly proportional to the current density.
With the very low "on" resistance (rds) of mosfets and using larger wire, higher current is no problem.
Unlike BJT's you can add more in parallel for more current.
Only enough volage is used to get the required amount of current. The va rating has little to do with it all. It's the current.
Have no idea what you are talking about on Satchid and "my system"...which system?
Yes UFO, I have read and enjoyed many of your older postings regarding motors and generators.
This is the area in which you excel, not electronics. So I can see why you prefer to use a mechanical switch.
So please refrain from posting wrongful information that does nothing but confuse people.
All the best to you and hope you succeed.
Elcheapo
Originally posted by bistander View PostHi Ufo,
In most text books and courses on the subject of AC dynamos develop and teach the concept of the rotating magnetic field developed from polyphase excitation of the stator. Without the rotor motion (stalled), this is traveling magnetic field around the air gap thru the machine's steel structure.
Note that the rotor can be removed and replaced with a metal egg. Likely what Tesla did. I believe Tesla is credited with discovery of this rotating field.
Yes, am familiar with polyphase tech, for instance a three phase would be alternated, overlapped AC sinewaves...pretty similar to 3 Phase DC Brushless Motors, except they are square waves...
The Magnetic effect caused in a static rotor on either of these machines is completely different than Figuera's concept.
The transit of the Field through Stator is always fed with same Intensity of Currents, so no "weaker and stronger fields here, moving in unison" by currents fluctuations increase-decrease levels, but due to AC Sine Fluctuations.
Originally posted by bistander View PostBut yes, the moving field in this case does swing +/-. Each half cycle is unidirectional. Does' t that count?
Originally posted by bistander View PostCould you not just bias the AC applied with a DC level sufficient to keep the magnetic field from changing direction? I was about to suggest this to you on the other thread where you were using a stator before getting engrossed with Figuera.
Oh well. Carry on.
Besides it would be "randomly" accessed to supposedly now Induced static rotor Coils, where alignment related to Stator Positioning will not be following an organized and Directional as accurately displacement of Hi-Lo Fields Sequence.
I would love that anyone here would be able to just "feel" this huge, extreme fluctuations of both interacting primaries with secondary in the middle...it is a completely different feeling than anything I have tested before...the Secondary tends to "hover" in some kind of gravitational state at higher frequencies between both primaries...never before experienced such result on a heavy piece of steel with coils...honestly.
Figuera is a "unique" scenario of Fluctuating Magnetic Fields Bistander...please try to understand that fact.
UfopoliticsLast edited by Ufopolitics; 12-13-2016, 08:36 PM.
" I have tested MM Toroid and it works excellent!! "
MM Toroid = ends closed winding, no opening.
Mine, bistander, Netica, ... Toroid = open winding.
/ ArneLast edited by seaad; 12-13-2016, 10:53 PM.
Rotating field
Originally posted by Ufopolitics View PostCould You please explain, how would a stalled 3 Phase wound rotor would "see" this same principle??!!
Oh well. Carry on.
And YES...
Hello to All,
And so...YES, I have tested MM Toroid and it works excellent!!...beyond expectations!!. and it is MUCH BETTER SYSTEM than Resistors alone, while it does NOT deform the MAIN SIGNAL WAVE.
I am only having Issues with the piece of crap PSU I've got, which can not drive such low resistance with Full VA Power, reason why I am stuck with Toroid Concept, since I am unable to test different windings and contacts separations (taps)...but do not worry, I will solve that issue soon.
The reason why I am doing Resistors as well is just to PROVE MAIN CONCEPT...Something that should have been done years back...but hey, someone has to do it...and so, like I said before, I got a good deal on High Power EBG Resistors of 10 ohms each at 300 Watts...so I will just use like 9 resistors to test system with crappy PSU...This way I would be able to test very LOW RESISTANCE HIGH CURRENTS AND VOLTAGE Primaries in an extended time.
I tested before with low power resistors and same PSU and I verified IT DOES WORK PERFECTLY WELL...just that they started smoking and had to stop test...So I could not make a longer video showing it.
Outside of this Forum...typical People would be completely lost by showing a very complex switching-fluctuating currents and magnetic fields development Setup...out of which, no one would be able to understand by showing original drawing on Patent...so, a very close system to that described ON PATENT DRAWING originally in 1908 MUST BE DONE FIRST, in order just to START PROVING CONCEPT....That it is not reliable?...True...but after all it was just cited as an EXAMPLE on Patent.
And so THE EXAMPLE shows Principle on Patent WORKS.
This way- As I understand it- IS THE WAY Science Developments Works......and NOT jumping the Gun at all times.
This is my Progress Status so far...plus Holidays time will kill me with mail orders.
UfopoliticsLast edited by Ufopolitics; 12-13-2016, 03:14 PM.
