Wrong, wrong and still wrong
Seaad,
You can not draw final conclusions about Part G by building it or simulating it, based on the completely wrong, opposite and distorted construction approach , which diverges completely from the already specified patterns
You have so many wrong concepts above that are hard to cite, but I will try to bring up just the primary, essential ones which differ from original spec's.
1- You are using Square Wave, Not good, it is not an abruptly, steep, radical raise and fall signal. Besides you drop it to zero, which collapses the field, also a negative way to replicate this component.
The Signal must be slowly, gradually ascending as the same way it must drop slowly and smoothly downwards, and never reaching zero values.
2-You are using Opposite plus Independent, separated windings, And Both are completely far from the original specified spec's.
It is just ONE winding, same awg, same direction through the whole toroid core.
Just based on the two wrong methods you have utilized and cited above, your results are completely off, and far away from original part G construction.
You have completely wasted all your time by doing all this work.
Originally posted by seaad
Seaad,
