Pole orientation
The discussion about pole orientation comes from time ago. The problem is that Figuera in 1908 patent did not clearly stated the pole orientation (nor in the 1908 patent, neither Buforn did it in his latter 5 more patents !!!). I will copy literally what it is written in the 1908 patent (both in the text and in the claims) so that everyone may judge if this a properly way of defining the pole orientation or maybe it is just a patent notation “trick” using the letters “N” and “S”
IN THE DESCRIPTION: “Suppose that electromagnets are represented by rectangles N and S. Between their poles is located the induced circuit represented by the line “y” (small)”
IN THE CLAIMS: “The machine is essentially characterized by two series of electromagnets which form the inductor circuit, between whose poles the reels of the induced are properly placed.”
What a way of defining the pole orientation just by calling them as "rectangles N and S" !!!. Note that Figuera left the claims open to any kind of orientation. Suspicious? ...
Buforn filed 5 more patents after Figuera's death in 1908, and he also avoid defining the pole orientation: Buforn also used the notation N and S, but never explicitly stated the pole orientation. I have not translated those patents because they all are exact copies of the Figuera 1908 patent. More literature but the same device. You can see it by comparing Buforn's drawings with the drawing from Figuera in 1908.... almost photocopies.
