wireless electiricity is here!!
  • wireless electiricity is here!!
    Simple Wireless Electricity - Part II - The BAC's - YouTube
    does anybody know this guy?
    Marketing devision ?
    Unfortunately my Junky home computer can't see You tubes
    But I can read
    Slider?
    He's one of our Peeps!!
    "the right stuff"
    See here
    http://www.energeticforum.com/renewa...tml#post212523
    Thx
    Chet
    BE that change !!
      Thank you logos for the thread and enthusiasm
      The intention has been for the simplest system and easiest for people to build at home. An introduction method for wireless transmission with an AA or lower voltages.
      The video above is the next step up, higher voltages and regulation of the input current by novel means.
      The small telephone/modem wire and signal transistor system runs at about 1MHz, current draw 20mA. MongrelShark and mnsman1 have kindly replicated and shown scope results as well as other findings.
      There are similarities to the Slayer Exciter and Lasersaber's SJR 3.0. Both are in my own background and a lot of folks here..so hopefully this system is of use as widely.
      Water regulation is one new area for the Part II version in the video. It 'just works', intending to move from heating resistors and bring in more natural methods of Base trigger control. The Earth itself as a Base trigger is intended for experimentations today, if it quits raining and will open up possibilities of better load feedback. The aim there is to emulate longitudinal signalling, although not yet tuned to produce the push-pull driving method.
      The electrolysis and seeming copper sulphate production are side effects needing more exploration. Dropping LED's into the water and them lighting is a fun aside.
      Current can be limited more conventionally with an incandescent bulb, as used in the Bedini SSG or TV degauss coils (once had a degauss coil heat til the plastic insulation melted lol, was cold with a house bulb in series).
      The 1 wire system is something I like a lot, noticing little loss (none visually noted but not lumen tested) to 60ft so far.
      A pancake coil connected to the end of the 1 wire can act as an amplifier and repeater stage, yet still allow the powering of mains loads (nightlight in the video), while also working as an extended 'range' wireless source.
      Yes, as Ramset linked, all is part of the hoped for demo to the new Wardenclyffe owners - of real, practical, easy to understand Tesla systems. Things we can build with what we have at home.
      From theory, to practice, to useful 21st century applications as part of the science center.
      Say, Ramset, have you tried a live-CD running something like Peppermint Linux ? Just download, burn and reboot. Nothing gets changed on your hard drive and it works well on my 1.6GHz 2002 vintage PC.
      More info here: Peppermint OS
        Hey Slider, the Fairies and Pixies must really love you !!!!!
        Though - what about a high single fine wire only - ie. NO ground ?
        At the far wire end, connect back to back polarity reversed LEDs between wire and centre pancake inner. Leave outer braid open circuit at centre, but join braid and inner at edge of pancake.
        Then from indoors, find the wire line drive radio frequency at which the pancake will free space resonate with respect to the wire, and thereby cause the LEDs to light.
        Just a suggestion.
        Cheers ........... Graham.
          Hey Graham,
          Good thoughts. Easiest with a signal generator though. I would think the idea would be a self contained tunable inductor circuit when the approximate frequency range was found. It would likely drift with sunlight, at night and during storms...several reasons there to experiment
          Drift would have to be auto recalibrating, perhaps a hunting circuit which constantly assesses the return signal, via a simple comparator. Saying that, if the drift circuit worked well enough then the rest of the circuit could find the resonance peak itself and we'd just let it have at it !
