Simlified solar charger/Tesla switch
  • Simlified solar charger/Tesla switch
    Here is schema for solar charger I come up with. Any comments or recommendations are welcome.
    FYI ... Yes I built it and yes it works.
    Replaced 1k resistor with 47 Ohm. Charging even in very low light.
    Mike
    hi mike
    can i know all the values for replication and also will it run with 36 v - 2 10 w
      Or just tell us what you used for the caps, and the type of transistor.
      The main difference I see on this circuit is that it does not have coils. I'll bet that if it did, it might have an even better output.
      I'll try this too, as I have a lot of huge jungle trees around my yard, blocking some direct sunlight.
      I think that it is very important to have a micro inverter for nearly every solar panel, when joining more that just a couple of panels.
      As the solar panels combined current output is only a strong as the weakest panel in the chain.
