Very cold nuclear fusion
  • Very cold nuclear fusion
    very cold nuclear fusion
    Are nuclear reactions that take place at ambient temperature without expending energy in a fuel cell tripolar:
    Heavy water electrolysis:
    RTFTechnologies D2O Electrolyser
      other reactions here:
      Nuclear fusion - Wikipedia, the free encyclopedia
        It 's still further by the establishment of the third central electrode.
        here is how to build a traditional fuel cell:
          Franco what happens if we put HHO gas instead of hydrogen inside fuel cell? How many hours does the black platinum coating lasts?
          The pure in heart will see the light.
            I would send HHO in the electrode center to create the electronegativity necessary to the movement of electrons (with oxygen), but then I do not know if oxygen affects then the nuclear reactions
            Autocostruzione
              Double tripolar fuel cell, also for ammonia:
                Build a tripolar fuel cell
                The slabs are external structural acrylic 3 mm, with the tubes for the entry and the exit of gas.
                The rubber seals have the function of spacing and sealing.
                The electrodes are made of nickel marks by cutting from a wire gauze with a mesh to about 50 mesh, leaving the existing terminals. These electrodes must be activated by immersing them (after it is degreased) in a solution of platinum chloride to 5%, as long as they have assumed a black color. After rinsing in water and natural drying in the air, are ready to be assembled.
                Between the electrodes is placed the diaphragm which is made from a thin layer of anion resin mounted on filter paper. It should also be soaked, before assembly, electrolyte, immersing it in a solution that prepares dissolving 30 g of potassium hydroxide in 100 cc of distilled water.
                Finally tighten the screws with the whole
                  Franco,
                  Looks interesting. Have you built a functional unit? If so, please share via YouTube video if possible.
                  IndianaBoys
                    Build, howewer, a geiger counter:
                    How to build Your Own Geiger Counter, pg. 1
                    and a neutron detector:
                    http://www.fas.org/sgp/othergov/doe/...s/00326408.pdf
                    _______________________
                    Autocostruzione
                      thanks man this is sweet
                        What happens with atomic hydrogen in the center electrode?
                          You can assemble a tripolar fuel cell also with two of this kit:
                          Rew-Power© reversibile da assemblare. | Store | Hydrogen & fuel-cell european megastore
                          ___________________________
                          Autocostruzione
                          • #14
                            The amazing thing is that if you want to use deuterium and hydrogen,
                            you do not need a dedicated electrolyser for heavy water,
                            everything is done with the cell reversible:
                            D2O + electricity = D2 + O2
                            H2O + electricity = H2 + O2
                            • #15
                              This is the basic kit:
