The GEGENE : a Great Efficiency GENErator with a Tesla bifilar coil
    I wondering why Mr. Naudin doesn't completely close the loop.
    He does refer to this work by Romero UK:
    TEST #4 : First test of a closed loop system with the GEGENE by "Romero UK"
      Why not feed the output from the pancake coil to a step-down transformer, then rectify it, store the charge in a capacitor bank, and then feed it into an inverter, and then the inverter output into the induction stove.
      From the output from the pancake coil to the input of the induction stove, add the appropriate types and amounts of load to equalize consumption with production.
      Because it only works on resistive loads, thats the advantage to testing this stuff instead of just talking about it, you actually can answer your own questions and stop looking like a blind man in a lit maze. Doers answer questions, sayers just keep asking.
        Einstein, Stephen Hawking etc might beg to differ.
        • Since neither of those guys are actually participating in the search for alternative energy that is a moot point. Most real scientists do research to prove or disprove a theory. Isaac Newton, Luther Burbank and thousands of others actually did research to clarify and try to prove their theories. I have learned way more by actually doing something rather than just reading about it.
          Respectfully,
          Carroll
            ...well, how about Tom Bearden?
            The idea that the only people who matter are those with an oily rag in their trouser pocket is tired and foolish. A good team contains all types and skills because that is what it takes.
            • When you show me an actual MEG that works like Tom Beardon says it should then I'll be a believer. But so far I have only seen failures based on Beardon's ideas. Up to now I have only seen evidence from him that proves Matt is right. Without hands on experience you are only guessing something will work or not. I think some of Tom's theories may be right on, but putting them to practical use is a whole different thing.
              Respectfully,
              Carroll
              • Induction hobs for £29; For ideal Gegene research:
                https://www.aldi.co.uk/en/specialbuy...duction-hob-2/
                Time limited offer. Thursday May 7th 2015 till Sunday. Could be dependent on locality. Check with your nearest Aldi.
                • Originally posted by wrtner View Post
                  This offer has expired but today, Thursday May 11th 2015, I found a considerable stock of the same unit, but made by Slivercrest, on sale at Lidl.
                  • Here we see OU, these are the words of the investigator.
                    My crude measurements show 600w / 5.4amp input,but an estimated 3KW output
                    [VIDEO]https://www.youtube.com/watch?v=5zlBsDE4rEs[/VIDEO]
                    • Here a video about the test of the GEGENE loaded at full power with 3550 Watts of halogen lamps while the power input is limited to 2000 watts...
                      [VIDEO]https://www.youtube.com/watch?v=Q5EoCKPkGT0[/VIDEO]
                      • From GEORGE CHANIOTAKIS
                        RESULTS
                        Against measure the voltage output, maybe because is OVER 600 volt the current is 6.0 AMP for powering the halogen lamps SO 600VOLT * 6.0 AMP=3600WATT.
                        The electrical power input of the induction cooker is measured 233 VOLT AND 4.30 AMP =1001WATT
                        [VIDEO]https://www.youtube.com/watch?v=3_m7QGPIn2c[/VIDEO]
                        • RWGresearchLive
                          Manual Over Ride Of Induction Cooker For GEGENE project..
                          [VIDEO]https://www.youtube.com/watch?v=pyH9PMZf8g8[/VIDEO]
                          • augsburgtech
                            Tesla bifilar spule coil with mit overunity !! Free Energy ! in 1000 watt out 3000watt
                            Tesla bifilar spule mit induktionskochpplatte
                            Eingangsleistung 230 v 4,5 A ca.1000watt 50 hz
                            An der bifilar spule angeschlossen 10 x 100 watt glühbirnen und ein 2000watt heizstrahler
                            ausgang an der bifilar spule 60v ac 20khz 32 amper
                            thanks at naudin .....
                            [VIDEO]https://www.youtube.com/watch?v=xE1JFxN6R6g[/VIDEO]
                            • TheOldScientist
                              Tesla Radiant Energy, highest energy gain from the Bifilar spiral coil
                              70watts input and 200 watts Output
                              [VIDEO]https://www.youtube.com/watch?v=2kOQr7hZA70[/VIDEO]
                              United States Patent Number 512,340 - COIL FOR ELECTROMAGNETS - Nikola Tesla. The Bifilar Tesla coil is capable to hold more charge then an ordinary coil. I put it to the test with various set-up combination to the load. Please compare it with my previous video of resonant coils. The second part is showing the storing of energy on capacitors. Goal is to charge fast enough to reach mains frequency for a step down transformer. Music is used with permission from WingMakers.com, All Rights Reserved. Song: AA Chamber 6 and 21
                              • bifilar pancake coil energy reached maximum
                                900 watts input and 2600 watts output.
                                [VIDEO]https://www.youtube.com/watch?v=8Ug7d2iBJ24[/VIDEO]
