hi all, ive been playing around with this for awhile now, and have had alot of fun doing it, im hoping others might be of some help in improving what i have and maybe even interest others into making 1 themselves.
its made from very good quality single strand copper wire, the transmitter i used 10 wires and joined them at either end to make 1 thick multi stranded wire, so being bifilar the spiral has 20 single stranded wires in it (2 x 10). the outer coil is single stranded which is wrapped around 40 times (just a guess?) i also wound 2 perminant receivers into the coil,1 i attached to an antenna and ground and the other i just experiment with and or run lights off it, it runs from either 1, 2 or 3 AA batterys, when using 3 AA batterys the coil squeals with the sound of high voltage and the raw power transistor gets fairly hot, when using 3AAs i can also flip over the receiver coil and the lights will still work at around 1/4 brightness.
im using a simple setup, c4429 transistor with a 100ohm resistor and cap between the base and coil. i blew up all my other transistors and the c4429 was all i had left to use
the second coil in the video was just an experiment i done, it only shared the same ground and it turns itself on when i use the large coil.
anyway heres the video, click on the picture to open the video
the receiver has 20 leds and the motor is a 12VD motor run from the primary, im not sure on the motors voltage? the leds are at a blinding brightness and the motor is running at its full speed using 2AA's
