Joseph Papp, Air Inert Gas Design, by Heinz Klostermann
  • #16
    Originally posted by tutanka View Post
    Air can be ignited simply respecting simple conditions. I have tested this condition in my latest reactor and the air is transformed in gas and is burned at the same time.
    Papp and Klostermann ignites the air gas to push a piston like in an engine to make electricity.
    What do you do with your gas?
    • #17
      From my experiments I confirm that air can be ignited in particular conditions and appear like methane flame..
      • #18
        hi, tutanka, I use n2 membrane pt, eec, neodymium mg to product. burnable gas
        • #19
          Interesting tut, I look forward to seeing your developments. Have you powered an engine with your methane?
          Is the energy output > than input?
          If so, where do you think the extra energy comes from? Nuclear, atomic, electron spin, ZPE, aether or somewhere else?
          • #20
            No methane, the process transform the air in blue flame directly !! Some ionized heat at about 3000°F!! I obtain more of 25Kw of thermal power.
            • #21
              Tutanka, your reactor is similar to this?
              • #22
                Interesting that you can reach 3000F with just air
                Do you need water in the air, humidity, for the process to work?
                What do you use the 25kw of thermal energy for, what kind of applications? Spin a turbine? Fuel a car engine?
                • #23
                  Originally posted by tachyon View Post
                  lithium is very important.. about water it's not the key element here , it only helps because of plasma expansion but energy is not coming from water!
                  Where then is the energy coming from? Nuclear, ZPE, aether or something else?
                  • #24
                    Air is as fuel in that reaction.. you can use water for increase the power. The process creates heat ionized in this way I can apply MHD tech for electricity creation.. but not now..
                    • #25
                      Air Burning
                      Here the small video that prove that really air burning air burning - YouTube
                      • #26
                        No sorry .. This is advanced system.. I don't producing ammonia or nitrous oxide.. I use just air as fuel!!
                        • #27
                          Very interesting, good gas flow. Can the gas fuel an engine (combustion with spark)?
                          • #28
                            You don't read or you don't want understand
                            The system process air and burn that immediately.
                            You obtain only some ionized heat in output.
                            • #29
                              Reactor?
                              Tutanka,
                              Great vid. Are you using a high voltage plasma to ignite the air passing through your reactor.
                              This is what Heinz seemed to be doing with his piston throwing experiment.
                              This is a very thought provoking thread.
                              70% nitrogen in the air we breath.
                              Stephen
                              Potential, is a terrible thing to waste.
                              • #30
                                Tesla Patent with a friction device supplying the sparc gap with a continuous
                                air flow. Is this the simple condition you are talking about?
                                Do you use magnets in the sparc gap , or would a simple setup like
                                William Lyne 'FES' -Tube work?
                                Please give us a few more hints.
