Hello,
i have been working on the AUL effect for 18 months now, on and off.
I'm not very knowledgeable electronics-wise, i only learn what i need to know in order to move forward and this is the only effect i'm working with, as it is quite rewarding.
For those who don't know, the AUL effect results in rotor speedup and input current drop when a load is attached to the generator coil or the generator coil is shorted.
The effect appears when you have a coil of high inductance being driven at a high frequency, typically 200Hz or more.
It seems to be to do with retarding the rise-time of the coil, the rise time of the coil is calculated by dividing the coil's inductance by it's resistance plus the resistance of the load.
If the coil is short-circuited rather than loaded then the load resistance is zero.
So far, i have explored the effect using three device incarnations.
1. A pulse-motor driven by Bedini's SSG circuit.
2. A multi-magnet rotor driven by a DC motor.
3. A simple transformer.
In my pulse-motor version i make it as simple as possible, using a diametrically magnetised neo magnet, so there is no rotor, just the magnet on a shaft. This is a light and fast setup that results in RPM's of up to 30,000 :
https://www.youtube.com/watch?v=s8lI...KV7znA&index=7
In my multi-magnet rotor version, i use a DC motor to drive the rotor.
I don't use the SSG circuit in this incarnation as the motor i use gives me more RPM's with less current input than the SSG :
https://www.youtube.com/watch?v=BLTc...KV7znA&index=6
Finally, in the transformer version, i made a very simple transformer, the primary coil being of high-current and the secondary being of high voltage/impedance, with a large rise time.
I pulse the primary with a square-wave generator, finding the frequency that gives the highest voltage output and this results in the best AUL effect.
I use grain-oriented laminations in the transformer. Obviously, in the transformer version, i don't get acceleration, just input current drop :
https://www.youtube.com/watch?v=_XLX...KV7znA&index=5
I apologise for my bad video quality but it is clear enough, along with this post, to see what's going on.
The interesting thing about this effect is that, the higher the rise-time of the coil (the more turns it has), the better the effect is.
I recently wound a 2LB AUL coil that, when used in the transformer version, resulted in a 50% drop in input current.
Unfortunately, when i added a further pound of wire to the 2LB coil my endcap came off while the coil was winding and i spoilt the entire coil assembly :
![](http://i1235.photobucket.com/albums/ff437/deepcut71/DSC02762_zps4320ccc6.jpg)
I'm sure this has happened to a lot of us here ;+}
I have more wire on the way, plus materials for a new coil-former as my next coil will be a 4LB coil.
I would love to know if anyone here has any experience with this effect and what are their thoughts on it ?
Some people say that, because we are retarding the rise-time, thus delaying the CEMF, that is why the input current drop and rotor acceleration occur.
This seems intuitively correct, but i have retarded the rise-time by up to 30ms, a magnet on a fast rotor can move quite a few centimetres in 30ms, far enough so that the next magnet is coming in, and you would expect the next magnet to slow down.
Other people think it's to do with parasitic capacitance, something that's been designed-out of electronics for years as it introduces unwanted noise.
While reading Eric Dollard's Tesla Transformer book i began to think perhaps it's to do with displacement current ... who knows.
Any thoughts/comments/ideas are obviously very welcome![Smile](http://www.energeticforum.com/core/images/smilies/smile.png)
All the best.
All the best.
