aluminum wire vs copper wire for electromagnets
  • aluminum wire vs copper wire for electromagnets
    does anybody have any experience using aluminum wire to make electromagnets?
    what are the differences in regards to regular copper wire?
    Use of aluminium wire is not a good idea as it can get very hot and cause fires.
    Regular service Signature:
      You can use aluminum but you need to stay within its ampacity rating. The same size copper wire can handle more amps. You would need a #10 aluminum wire to handle 20 amps compared to a #12 copper which handles 20 amps. A #12 aluminum can only handle 15 amps.
      Ampacity Charts
        I have been using Al-wire in some coils for transformers. It is a LOT cheaper, its conductance is slightly less (2.8 vs 1.7 *10^-8 Ohm.meter, I thought), it conducts heat better and it weighs much less.
        They are using it in old fashioned welding transformers (the 50/60 Hz ones). I have seen it being used for 7-24 KW transformers. So I guess its OK for that application.
        For electromagnets, I honestly don't know, but my guess would be that it would be safe to use.
        Ernst.
          Aluminum or copper, make sure you know How to Make Proper Wiring Connections
            Hi all,
            I have found aluminum coils in micro-wave HV transfo so I guess that makes the Al wire safe for domestic use. Just follow the rating of your particular wire size.
            Take care,
            Michel
