Kapanadze, Joseph Newman, Bashar Darryl Anka
  • Kapanadze, Joseph Newman, Bashar Darryl Anka
    I found a connection between those three entities, I will start with Bashar theory of space/time phenomena and I will start by giving an example that he used. Lets say that we have two twins, one travels in a spaceship around the earth at speed of light the other stays in the earth, 20 years passed and the twin that was in orbit comes back. That twin will age less than the one that was on earth, because he was traveling in the speed of light he used much less time and almost 100% space. Fallowing this example we end up with a diagram like this.
    Youtube link
    Bashar - Free Energy Space-Time Antenna - YouTube
    Motion is nothing more than an illusion, because our senses cannot perceive the millions of shifts that we do from reality to reality. So if the movement of our body is nothing more than shifts between reality we can say that everything is static that matter doesnt move, what actually moves is the information about a particular state within the gyroscopic particle.
    Quantum Entanglement allow us the teleportation of light particles photon, according with Prof. Anton Zeilinger from University of Vienna there is no distance limits, what happens is that the info of a particular photon is teleported and not himself.
    Quotes from Energy Machine of Joseph Newman!
    The release generates the magnetic field. When the input current is turned off, the collapsing (gyroscopic particle of the) magnetic field within the coil results in the gyroscopic particles attempting to return to the atoms from which they initially emanated.
    Two tests:
    First!
    Take 40-guage copper wire which has a resistance of 1,049 Ohms for 1000 feet with a total weight (of atoms composed of gyroscopic particles) of a mere .02993 lbs., turning same into a coil with a 10-foot interior diameter and 8.32 feet in height. One would therefore have approximately a mere 31.8 turns of cooper wire (cooper atoms, i.e. gyroscopic particles).
    If 100 volt is connected to coil 15-A (described above), then a current flow of approximately 95MA would occur with total power input of 9.5watts and resulting weak, magnetic field of .012 Gauss or a mere .000014 Joules of energy stored in this weak, magnetic field. And insignificant current flow would now occur if the current input was stopped and coil 15-A was shorted-out to collapse a weak magnetic field and provide an inductance of only .003 Henries.
    Second!
    Now, conduct another test with 5-guage copper wire which has resistance of .3133 Ohms for 1000 feet. However, to equal the same resistance as in 15-A above, one must now use 3,348,00 feet of 5-guage wire with a massive, total weight (of atoms composed of gyroscopic particles moving and traveling at speed of light, i.e. the mechanical essence of Einsteins Equation E=MC^2) of 335,469,6lbs. or 16.77 tons. Such wire is turned into a coil with a 10-foot interior diameter and 8.32-foot height. This structure would have approximately a phenomenal 90,000 turns of 5-tguage (cooper atoms). If 100volt were now connected to coil 15-B then a current flow a approximately 95MA could occur with a total power input of 9.5 watts and a resulting, phenomenally larger magnetic field of 23.7 Gauss, or 1,905 times larger for coil 15-B than for coil 15-A, and 116 Joules of energy stored in the magnetic field of Figure 15-B below. This represents a phenomenal 8 million times more energy than in the 40-guage coil of 15-A above. A phenomenally larger current flow would now occur if the current input was stopped and coil 15-B was shorted-out as a result of the collapsing, much greater magnetic field of the 5-gauge wire in coil 15-B. Such shorting would generate an inductance of 25,700 Henries, which is better than 8 million times the inductance of the 40-gauge coil in 15-A.
    So we can create bigger magnetic fields by using more amount of thinner wire, and we also can use the collapsed magnetic field.
    I found a diagram that looks just like bashar space/time diagram, here KAPANADZE 3 / FreeEnergyLT / FreeEnergyLT I dont know who has done it.
    And I had an idea, in the coil A we will have a larger diameter wire, in this wire we got gyroscopic particles travelling, when we wind the coil A around the smaller diameter coil B we will induce a voltage in the secondary winding, this voltage will be greater than the one we had in the coil A and that is because the wire used in the coil B has a smaller diameter so the gyroscopic particles activated within the coil B wont be as conditioned as the particles of the coil A, because we will be activating in the same space less particles so they will flow in a better way and also penetrate things easier, so if they have a better flow we will measure more volts per cycle. When we do the Step down is the inverse, we will be activating in the larger diameter wire more particles in the same Space, so they will move less faster because they have more particles around them, they wont penetrate as easy and because they do not penetrate as easy they will have more power, opposing what they face, because there is more particles together.
    When we mix my idea with bashar space/time diagram we end up with volt(space), I(time), which means that when we increase the volts we must be increasing the Travelling speed of the information, and I dont know if this is true by increasing the volt we should be increasing the travelling speed and consequently the space that we traveled and ofc we experience less time to travel in space.
    Now kapanadze device uses for sure the Newman theory, I think they use my idea because of the HV, and also the resonant effect that I read in some book that is like a swing we just use a bit of force in an exact moment and we will be able to increase the swing overall energy.
    The Ferromagnetic core may be to get a bigger magnetic field, by increasing the lines of flux so the ferromagnetic core is not imperative.
    To use the output of the kapanadze/don smith/tesla device we must step down voltages and rectify the frequency.
    I also want to point something, u guys remember what happened to the twins? What will happen to our voltage at very high speeds?
    Joseph Newman book
    Energy Machine of Joseph Newman.pdf download - 2shared
    Ok i know that my theory doesn't make sense because, the frequency doesn't increase when we increase the voltage when we make a step up.
      check chapter 3, http://www.free-energy-info.co.uk/ has good info about the don smith device, only when we undestand don smith device will we be able to undestand kapanadze. pag 43...
        Another thing that don smith speaks, is radio, the number of people listening radio doesn't affect the energy that they use to send the signal. Radio works at high frequency. Ofc u are limited in range by the frequency u use.
        Who was the founder of radio technology? Tesla, got basics from Marconi.
        What did Tesla said? "The present is theirs; the future, for which I really worked, is mine."
          i think i know how don smith/kapanadze device works, i will buy some mats, test and if im right telling how.
            Uploaded with ImageShack.us
              someone with the mats, test the coil described above and say something there.
                don smith uses the "jumbo speaker cable" single conductor with very high number of strands, in order to create a bigger magnetic field and thereby creating more flux lines that will cut the secondary activating, or propagating the "energy information, electric". Joseph Newman talks about this, that we can use higher gauge wire with more length in order to create bigger magnetic fields, instead of using low gauge wire, also a guy that understood this was Paul Babcock, i got a video of Paul Babcock presentation if anyone wants send message.
                  Pedro:
                  All good points about the coil windings, and using many strands, etz.
                  May be true, as even Steven Marks mentioned it related to his TPU devices, also. Soft, and flexible welding cable may be what will improve output performance.
                  Nick_Z
                    Another Russian built self-runner, again possibly utilizing some of Hendershots ideas.
                    It does run itself once started using a 12v, 0.8ah battery, and provides a 500 watts output or so, even with the start battery disconnected.
                    If anyone understands Russian, please help to explain what is being said.
                    Гость УСТАНОВКА - YouTube
                    Nick_Z
                      looks like a big ferrite rod he has in the middle right?
                      i think he fallowed this video
                      KACER - YouTube
                      but i don't understand anything... also would love a translation
                      a replication of the video linked above
                      caduceus coil on delamorto 1.wmv - YouTube
                        Originally posted by Nick_Z View Post
                        Pedro:
                        Nick_Z
                        Can u quote the video where Steven Marks speaks about that please? i didn't know that guy, i want to see what he says related to this.
                          It was mentioned a few years ago, in the overunity.com forum, under the TPU thread. But, I don't know where in the thread it was mentioned.
                          He was not using fine multi-strands wire in his TPU devices, that I know of.
                          What he said was that many strands can work better than a single one or just thicker wire.
                          His biggest 17 inch TPU device put out about 800 watts, or so.
                          This last self-running device that I just mentioned is putting out 1000 watts, and only uses the battery to kick-start the device. It is being discussed currently at the overunity.com under the Dally Replications thread, as well as the Kapanadze replications thread.
                          The difference in the kacher devices, and what is being worked on done now by the Russians, is that these don't need a constant input source to operate, like the kacher devices all do.
