CVD Diamond Synthesis
  • CVD Diamond Synthesis
    It's now possible to manufacture up-to-10-carat, perfect, colorless, clear, gem-quality diamonds in a process called chemical vapor deposition. Obviously, it's worth learning more about.
    Each of the videos below relate to the process known as CVD with respect to diamond synthesis.
    Diamond Labs (BBC Horizon Documentary)
    Synthetic Diamonds - YouTube
    How its made - Cultured Diamonds - YouTube
    Growing Synthetic Diamonds - YouTube
    Apollo Diamonds Part 1 of 2 - YouTube
    Apollo Diamonds Part 2 of 2 - YouTube
    Originally posted by Wikipedia
    CVD can be used to produce a synthetic diamond by creating the circumstances necessary for carbon atoms in a gas to settle on a substrate in crystalline form.
    CVD production of diamonds has received a great deal of attention in the materials sciences because it allows many new applications of diamonds that had previously been considered too difficult to make economical. CVD diamond growth typically occurs under low pressure (1–27 kPa; 0.145–3.926 psi; 7.5-203 Torr) and involves feeding varying amounts of gases into a chamber, energizing them and providing conditions for diamond growth on the substrate. The gases always include a carbon source, and typically include hydrogen as well, though the amounts used vary greatly depending on the type of diamond being grown. Energy sources include hot filament, microwave power, and arc discharges, among others. The energy source is intended to generate a plasma in which the gases are broken down and more complex chemistries occur. The actual chemical process for diamond growth is still under study and is complicated by the very wide variety of diamond growth processes used.
    Using CVD, films of diamond can be grown over large areas of substrate with control over the properties of the diamond produced. In the past, when high pressure high temperature (HPHT) techniques were used to produce a diamond, the result was typically very small free standing diamonds of varying sizes. With CVD diamond growth areas of greater than fifteen centimeters (six inches) diameter have been achieved and much larger areas are likely to be successfully coated with diamond in the future. Improving this process is key to enabling several important applications.
    The growth of diamond directly on a substrate allows the addition of many of diamond's important qualities to other materials. Since diamond has the highest thermal conductivity of any bulk material, layering diamond onto high heat producing electronics (such as optics and transistors) allows the diamond to be used as a heat sink.[12][13] Diamond films are being grown on valve rings, cutting tools, and other objects that benefit from diamond's hardness and exceedingly low wear rate. In each case the diamond growth must be carefully done to achieve the necessary adhesion onto the substrate. Diamond's very high scratch resistance and thermal conductivity, combined with a lower coefficient of thermal expansion than Pyrex glass, a coefficient of friction close to that of Teflon (Polytetrafluoroethylene) and strong lipophilicity would make it a nearly ideal non-stick coating for cookware if large substrate areas could be coated economically.
    CVD growth allows one to control the properties of the diamond produced. In the area of diamond growth, the word "diamond" is used as a description of any material primarily made up of sp3 bonded carbon, and there are many different types of diamond included in this. By regulating the processing parameters—especially the gases introduced, but also including the pressure the system is operated under, the temperature of the diamond, and the method of generating plasma—many different materials that can be considered diamond can be made. Single crystal diamond can be made containing various dopants.[14] Polycrystalline diamond consisting of grain sizes from several nanometers to several micrometers can be grown.[12][15] Some polycrystalline diamond grains are surrounded by thin, non-diamond carbon, while others are not. These different factors affect the diamond's hardness, smoothness, conductivity, optical properties and more.
    Source: Chemical vapor deposition - Wikipedia, the free encyclopedia
    Berg
    _____________________
    Recommended Reading: The Quantum Key
    Cvd
    Seocal | Seki-ASTeX: Diamond CVD, Carbon Nanotube, Laser Spectrometer
    also..
    Check out:
    Microwave Plasma-assisted CVD Polycrystalline Diamond Films Deposition At Higher Pressure Conditions by Stanley Shengxi Zuo.
    Berg
