Extremely efficient motor/generator
  • Extremely efficient motor/generator
    This motor generator when loaded down uses LESS watt power than when free running. Most all comercial motor generators when loaded down use MORE watt power.
    The manual battery charging/swapping portion of the setup is just a little icing on the cake.
    Needs electrical automation by an electronics guru.
    Anyone interested in replication should view the below link.
    LATEST AND GREATEST PART 2 - YouTube
    Tom
    Nice work Tom as I see you are still at it with this setup. Looks like you have it down to a science now. That's nice you can run a fan now to do some work. I would wonder if that shaft was hooked up to a small generator or PMG instead of the fan and the output of that generator routed to the run battery if you might have overunity if you don't already.
    Do you have schematics available of your setup? What size and type is your rotating magnet? Thanks for your continued research on this.
      the wheel
      Hi Tom, very nice set-up.
      In part 1 you use a 6in. wheel ,but in this one it's different. In the first one ,you could have placed coils around the wheel and produced more power.
      What are the control boxes? Also it looked like the coil under the wheel is offset from center?
      I'd like to give this a try,but more detail is needed, I already have the magnet wheel ,just need to know how big the coil is, placement ,and how to feed it (the boxes)?
      Thanks shylo
