These are the circuits I use.
I stuck some tar foil strips to the rotor and put an rpr-220 photo-reflector on
an arm that swings in a small arc for timing adjustment.
Optical Senor module
![](http://i227.photobucket.com/albums/dd168/Toey1/Opticalsensormodule-22.jpg)
Then the squared signal from the sensor module is sent to the signal
processing board, which uses a CD4047 to process the signal to the desired
width.
![](http://i227.photobucket.com/albums/dd168/Toey1/Signalprocessorboardsm.jpg)
However I don't use bipolar transistors much as switches, I use mosfets for
switches, and mosfet drivers to drive them with, the pull down resistors are mainly
2 k to 10 k usually 10 kOhms. Usually a 100 uf capacitor to ensure the mosfet
driver can get enough juice quick and a smaller one in parallel with it for good
measure. I use 5 volt signal to the chip but the chip drives the mosfet with 12 volts,
but it could drive the NPN with 5 volts maybe....
I think a driver chip would drive a bipolar transistor. But I'm not sure how it
well it would work.
I'm using two IRF740 in parallel and they barely get warm passing 4 or 5 Amps.
The faster turn off will give the better spikes for sure.
I also use a picaxe to control a boost converter to adjust the supply voltage so
the 5 volts for me is already there to use.
Using Ohms law if 12 volts is applied to the base of the NPN,
then 12v /10 000 Ohms = 1.2 mA
and 12/ 2000 Ohms = 6 mA
not much.
width.
well it would work.
not much.
