Wesley, a TK researcher over at Overunity.com (user name stivep) just proved that in certain environments (e.g. inside RF fields) even normally stable nuclei can decay. He partially replicated Harold Victor Colman's 1956 British Patent and picked up Beta radiation from non-radioactive materials. The next phase is to extract electrical current, work in progress.
Wesley Video's:
Revolution has begun Free Energy Exposed part3 - YouTube
"A new apparatus for producing an electric current"
www.rexresearch.com/colman/GB763062A.pdf
According to the present invention we provide apparatus comprising a generator unit said unit including a magnet adapted to produce a magnetic field, means for suspending a chemical mixture in said field, said mixture being composed of elements whose nuclei becomes unstable as a result of bombardment by short waves so that the elements become radio-active and also release electrical energy, said mixture being mounted between and in electrical contact with a pair of different metals, such as copper and zinc, a condenser mounted between said metals, a terminal electrically connected to each said metal, means for conveying said waves to said mixture and a lead shield surrounding said unit to prevent harmful radiation from said mixture.
The mixture is preferably composed of the elements Cadmium, Phosphorus and Cobalt having Atomic Weights of 112, 31 and 59 respectively. The mixture which may be of powdered form is mounted in a tube of non-conducting, high heat resistivity material and is compressed between granulated zinc at one end of the tube and granulated copper at the other end, the ends of the tube being closed by brass caps 30 and the tube being carried in a suitable cradle so that it is located between the poles of the magnet.
Theory for Nuclear Beta Decay as an Energy Source
Overunity.com member, user name verpies sums it up:
"There is another way to look at it: The EM environment affects the stability of the nuclei.
There is more evidence of this influence here.
Cowan and Reines Neutrino Experiment
Contemporary science acknowledges the stimulation of light emission but not the stimulation of beta decay.
Also, it is important to notice, that experiments do not detect free neutrons in beta decay. They only detect electrons/positrons and deduce neutrinos/antineutrinos. Free neutrons are synthesized only in reverse-beta reactions and are easily absorbed by Cadmium atoms (e.g.: in CdCl2) with subsequent emission of a gamma ray. See the Cowan experiment.
Neutrinos/antineutrinos are only deduced since they are near impossible to detect directly.
...and according to Miles Mathis those extra neutrinos are not really emitted in beta decay but they are the result of bad accounting:
P.S.
The Miles Mathis paper, I recently quoted, explains a mechanism of the neutron decay as a collision with external electrons/positrons, suggesting that beta decay always has a cause that is external to the nucleus."
Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Ref:
- Radioactive decay, Changing decay rates
Radioactive decay - Wikipedia, the free encyclopedia
- Introductory NMR & MRI: Video 01: Precession and Resonance
Introductory NMR & MRI: Video 01: Precession and Resonance - YouTube
- Film badge dosimeter
You can differentiate between beta and gamma with a high ISO photo film with and without aluminum foil.
Film badge dosimeter - Wikipedia, the free encyclopedia
- Neutrons are much harder to detect.
The CdCl2 that Wesley uses, is good at catching slow neutrons and converting them to gamma. When beta particles are shielded with heavy elements (e.g. Pb) it is worse than shielding them with light elements (e.g. Al) because heavy elements convert beta particles to X-Ray radiation through Bremsstrahlung effect. However Pb is better for shielding gamma radiation.
- It is interesting to consider the non-chemical properties of Cobalt and Cadmium.
Both elements are good neutron absorbers that emit gamma rays as an end result of this absorption.
59Co absorbs a neutron and converts to 60Co which then beta decays to 60Ni emitting a fast electron and an antineutrino, next the 60Ni emits two strong gamma rays.
-Also, what the hell is counterspace ?
It is a polar reciprocal of Euclidean space (1/s), that is the result of subunit transform in Projective Geometry (also see here).
This is what you get when you try to get below one quantum of space and that's why some people call it "inner space".
The natural movement in space is linear while the natural movement in counterspace is rotational (yet aperiodic). See here.
Miles Mathis proved, that below one quantum, tangential velocity of c in space was equivalent to an orbital velocity of 1/c in counterspace. See here.
http://api.viglink.com/api/click?for...36613800217310
More Proof of the Reality of the Charge Field
More Proof of the Reality of the Charge Field by Miles Mathis
Counterspace is an an essential concept for understanding modern physics. You'd be wise to learn it.
- Calcium Metaphosphate contains Phosphorus, Calcium and Oxygen.
"C" is an additional unreacted element - Carbon, that is mixed with the Calcium Metaphosphate.
Metaphosphoric Acid + Calcium Hydroxide ---> Calcium Metaphosphate + Water
1 part Co(No3)2 6H2O
2 parts CdCl2
3 parts of 3Ca (PO3)2 + 10C
Could be that a old technology from Thomas Edison, way back in 1903, to Coleman 1956 and Reiss 1982 patents, using NM Resonance, crossed with a magnetic field to stimulate Beta decay, to then create electrical energy from matter?!
More to follow...
Wesley Video's:
P.S.
Ref:
2 parts CdCl2
More to follow...
