Free energy already exist
  • #46
    After I make the video and present this device I will be running it at full blast 24/7. I know that the house where I'm living uses more than 3500 watts so even though I will not be eliminating my electric bill completely in the beginning I should still be saving allot unless the machine malfunctions and if that happens it can throw of the frequency/screw up the voltage which in turn can damage what ever is hooked into it and if that happens it may just blow fuses or worse but from what I can tell it looks like the only thing I truly have to worry about is the old parts and heat.
    No matter what after the first model is 100% complete (all gauges, safety equipment, and cosmetic adjustments) I plan to build 2 more than disconnect myself from the grid completely.
    • #47
      The Difference of Sharing...
      Originally posted by inventionmaster View Post
      Even though my setup works I'm still in the beginning stages and still making modifications to get the absolutely best performance that I can afford to achieve. The only reason why I chose to build this thing now instead of later is to beat the summer electric bills. As I was browsing generators on-line I just happens to come across one that had an output big enough to make a difference.
      There is a BIG difference and mainly a GREAT Relief when You Share your discovery/knowledge/research/invention(s) in the Open.
      If You use an anonymous name (like most of Us do here)...then, what kind of "Personal Recognition" could you be willing to obtain?
      When You Open Source a Device(s)...You are not only helping others...but also yourself...there are MANY Bright Minds here, that if you open up your troubles/doubts/fears...etc...they will help you without any "interest" in return...yes for free.
      It is almost impossible for just ONE Mind to develop everything required from Electronic Controls to the final Electrodynamic Machine, passing by all the Machine Work Involved...and, even IF He/She could go by themselves...it would take MUCH, much longer to accomplish a final product...rather than working in a closed Team.
      Once You Open Up a "Maybe Perfect, but Not Yet" Machine/Device/Apparatus...there would be many people contributing to enhance, perfection, develop different ways to obtain better performance....How?...When they replicate it in their Shops, Garages...Backyards, etc
      Most of the Past Inventors of FE Devices...were ruled by greed, ambition, power desires, Grand Ego ...and if you take a look at just one, cited at random...Ed Gray...so far No One has been able to run His Motors...even though, they recuperated a few in his Lab backyard... and restore them to Pristine Conditions...No One have -up to now- the slightest idea... How the Controllers are build, or even what are they after for the signals to output...He kept it secret till his grave...
      And If We all look at history...we will find very, extremely similar cases...Rory Johnson, Henry T. Moray, Floyd Sweet...Stan Meyer...Ed Gray...Arie DeGeus...etc,etc ...All this People were after a Patent, and got it...thinking that would be it...they did not know about the "1950's Inventor Secrecy Act"...The "Interest Letter Form" that the above level of the USPTO could send the Inventor(s)...the DoD and the DoE...
      Take care and good luck
      • #48
        Originally posted by Cornboy 555 View Post
        Hello Inventionmaster, just a sugestion, maybe you could post a pic of all the guts you took out of your standard generator, to make it OU, because it would take a Super Genius to work out how your invention works, just by looking at the GUTS.
        Regards Cornboy.
        Can't take any pictures until my replacement battery charger comes in.
        For all I know you could very well be that Super Genius who only needs to know what I used. I know that if somebody simply showed me all of the parts it probably would not take me long to figure it out. The first laptop I've ever used was in like 1,000,000 peaces and broken when it was given to me and without any guides, hints, or knowledge of what I was looking at (first time seeing the insides of or using a laptop) I was able to put it back together easily without even knowing what it looked like assembled and it worked afterwards and I even fixed what ever problem it had while I was at it.
        • #49
          Guessing "A Field" you could be working on...
          After I have read all your Posts...I believe You are re-using that Gas Engine Structure...without the gas tank...carburetor...etc,etc (Guts)...You just left the Mechanical Rotary Assy...like Piston, Counter Weights, and off the Heads...took off valves...and all the gears (Cams) that actuate them...also "Not Generating Electricity "Items"...
          Then Inserting/Adapting a Heavy Duty Coil where the Piston was...as also adding another "balanced" Coil in the Head Section...that also contours Piston Coil (in order that magnetic field is greater)...by using some mechanical contacts...you are able to energize both Coils at same time in a Repulsion Stage...so, instead of the Spark/Explosion...you are using a very powerful magnetic field repulsive force...then Counterweights do the "other half of rotation, as it contributes to the hammering effect required to obtain a great torque/speed...after a suitable High RPM is developed, the pulses/energy required to run this device is minimal...as it uses the reversed fields from Radiant to add propulsive power when is at off stage (disconnected/not energized)
          The thing is...I have also developed a similar type of reciprocating engine in the past like this, and I am still working on them (Not a Solenoid type, those work with attraction mode from the solenoid core into the coils tubing...and it is NOT as Powerful or fast...as the Repulsion types)...it works...but only when you step into very accurate/complex electronic pulsing systems...then you can even create a V12 Engine...
          Sounds familiar?
          • #50
            That is very true. Working in a small closed team would definitely be allot faster.
            As a matter of fact I absolutely hate mathI hate it.
            Most of the time I know precisely what calculations I need but when it comes time for me to do them it takes awhile. So many numbers. I don't know what I would do without calculators. I do wish to somehow work in small teams with future projects. There are so many things I wish to build so many things that would greatly benefit mankind!
            • #51
              Sounds familiar?
              Ooohh sooo close. but I'm using one coil. My wish is to later be able to somehow afford a more powerful generator and then I'll be using multiple coils. Sometimes I can sort of visualize how my projects will work before I build them and as I'm building I run test to insure that the ending results or final build will have a favorable outcome!!! Most key ingredients seem to be in the specs (weight, voltage, output, input, max load, max rpm, etc).
              • #52
                So Many Things...So Little Time
                Yes, that is exactly what we all have...very little time...even what we consider a "small" project could take decades to FULLY finish developing ...to then walk into a patent office somewhere...then getting a letter..."We are "Interested" in your Invention Sir..."...You are then...done.
                Why do you think we are not a Much Higher Civilization?
                Because we are a dumb, retarded...stupid race?
                Absolutely NOT!...We are very smart beings...but we put a huge brake in our Evolution, from long ago...when a Jewish merchant decided to start printing "Promissory Notes"...and start giving them to people that drop the real gold and jewels...then recovering any asset if they did not payback ...it developed further on in "Legal Tender Notes"...ever heard about them?
                We set too much value in this pieces of paper...and then we want more...and more...
                Do You think that Nikola Tesla would have been able to fully develop all his over 700 patents in just a "Lifetime"?...
                • #53
                  Hello Inventionmaster! I have just a simple question for you: how do you determine or measure the input and output power of your generator?
                  ...just to make sure you are not wasting your time...
                  I wish you all the best and good luck!
                  • #54
                    Yeah, you are using a Coil (as the Stationary-Stator where Head was) and a magnet mounted/inserted at Piston Crown...that way you do not need any contacts wiring at interior of machine...right...?
                    Are you using Neo's I hope?
                    • #55
                      I pretty much got lucky enough to not have to build what I needed. By utilizing a motorized force with the required specs I was able to achieve desirable results. Leaving me with the task of modifying and upgrading instead of trying and trying to get it to work. The generator is a go because the required energy to keep it going is far less then the left over power. I then simply dip into a little of the left over power to continue the rotation.
                      Other thoughts:
                      " I'm starting to get tired of repeating myself but that's OK because I am a kind person
                      • #56
                        So...You have something like this...
                        [IMG][/IMG]
                        But, instead of a Coil at Piston...you have a powerful magnet...You know magnets add drag and friction?...as they are only scalable up to certain proportions/sizes?...while coils are endlessly scalable...and no friction.
                        But, I guess you did not know...that when a Coil is cut off its power suddenly (steep square pulses)...they ALL reverse polarity?...as when it is very fast pulsed...it increases that reversed magnetic field, higher than originating field?
                        That is material from my first post here...
                        You see?...If You would have disclosed it ,..I would have been able to help you out...as also in the Mechanical balancing calculus...Oh...what a mess to do that...
                        I have done extensive development as prototypes/diagrams/CAD's, 3D Animated...and then some of this type of Machines...but, then I got involved in a better discovery/technology...that I have shared already...
                        I hate Pistons, too noisy...and on top...need to be submerged in Oil...when we could build much better/smoother machines...and No Oil required, except a drop at bearings...
                        • #57
                          No sorry. However what you described is extremely similar to one I wish to build from scratch (winding & building the motor/gen by hand) that way I'll have full control in what materials are used allowing me to fully minupulate how effecient that particular design will be.
                          • #58
                            Of course, the Gas Engine Crankshaft/Piston/Counterweight are already "Factory Balanced"...right?...and mounted on bearings...
                            Of course...once you get a suitable rotation/force...the required input to your "Head-Coils" are minimal...
                            I always repeated in my threads, videos...comments etc...
                            "If You take off the Counterweights from ANY Gas Engine...even balancing crankshaft...you will NEVER turn that Generator"
                            The Explosion/Spark...is just a "Prime Mover" to get UNBALANCED Weights going...(Weights are only balanced to Explosion Stage Pressure ) then Carburetor/Fuel Injection Pumps/System fuel feeding, reduces considerably..."saving gas" once started and reaching X RPM's...like 3600 for US...and 3000 for Europe and Australia...
                            Take care
                            • #59
                              Hi, inv-master;
                              Keep going no matter what !!
                              Look how many claimers of OU were here - Zilano; Cosmo - 5-10kWt of OU having at home;
                              Stivep - "working OU";
                              ProfessorGravity - AG thruster;
                              Ufopolitics - "WE GOT IT, OU!! skeptics are speechless!!"
                              And what?? They all gone! All, but ufo! Cuz they have it and using it , and ufo's still here - cuz it's not working , he was laughing at you, and now he goes "good luck", what a chameleon.
                              So, If you have it - just enjoy it, get profit of it, and when you ready just hit the World!!
                              Of course if you need help - bring it here, there's bunch of very clever, sober and smart people around, they will point you the best way.
                              Courage!!
                              • #60
                                Symmetrical Generators...
                                You will never, get to turn the Rotor/Stator of an existing brush or brushless Symmetrical generator...I mean, you could make it turn...but it will never produce full power out, if you pulse those coils to obtain rotation...it will not turn the 360º required,with static magnetic fields to fully induce the generating fields...sorry.
