here comes the fizz .. ewiz
Here comes you Sacred Geometry ewiz .. but not quite where you expected it me thinks
Ok .. I can sense every bodies champing at the bit and pondering if this or that machine may be a candidate …. There is a radical change in the theory of a very efficient machine and a machine that’s running COP +1, as you may have noticed with your own machines …. and certainly your machine tachyoncatcher … I'm sure you have noticed the more you throw at it …. the harder it responds whilst using no actual power its quite capable of throwing you around like a rag doll.
Over driven squirrel cage ah well great stuff .. Its surprising how many even seasoned electricians don’t realise the Tesla motor can make a very effective generator … and there is a little chunk of engineering that seems to be totally overlooked by almost every body when considering building a COP +1 machine . You see Real power is an anathema to free energy machines .. in fact its evil and an anathema to everything!! including our world
Tesla warned ….. you must consider the whole circuit … So assuming you build a machine where would you measure the Input power ? (You need a little for timing relative to this dimension)
I don’t mean how and with what and waveforms and all the never ending crap that naysayers produce. And I don’t mean where it might be convenient for you to stick a meter.
Or even where the electric company has fitted a meter …. Nature has its own natural progression
and cares little where you think it should be measured or how it should be measured.
As an educated guess I would say In natures scheme of things the circuit efficiency could be considered to be from the first transformer the circuit encounters .. in the case of the rotoverter this could be a sub-station some miles away. (The transformer because as EPD says the operation is not explicable .. or at least its not going to be taught to us)
So I am assuming that you actually enquire specifically about looping a system … if you take a look at the bog standard rotoverter the motor has to be extremely efficient .. into the very high 90 percent
It has to be very much bigger than would normally be required to drive the same load conventionally
even very slight drag has to be attended to …. the fan removed …. even the bearings carefully re lubricated … meticulous attention is given to the P.F (resonance) all of these physical adjustments have one aim …. to reduce the slip … conventional theory will tell you if there is no slip a Tesla motor can't run if it did then of course It is running on pure reactive power and all the laws and dogma is shattered... you are in resonance … using no power … yet obtaining usable energy
… balancing a ball on a ball...
So in practice what they did … was got very very close to “no slip” by all the standard methods
(which is where most were encouraged to stop …. that is at a very efficient system but never COP+1)
they then matched the wave form and injected just enough extra power to be running on reactive power .. there are of course more refinements … like grabbing every scrap of real power that may be circulating .. but essentially thats it!
So we come to look at this motley collection of motors .. the first and most important question is how efficient are they in normal operation ?
These motors are not designed to run on reactive power … but obviously Hectors ambition was to make a difference with machines you could buy off the shelf.
Because all reactive energy comes from the Aetheric sea and follows the harmonic and overtone resonance laws just like Radio waves … “as I pointed out before”
The Mathematical progression through a machine or machines is predictable and natural .. and as you have found out (Randy) .. quite staggering
in other words although building a rotoverter and getting the thing looped may seem very tedious with a great big motor for not very much return .. if you then drive another rotovertor with the output of the first one things alter very drastically indeed. We are grabbing these waves
What is the Casimir effect? : Scientific American and using them.
So whilst these guys debate the matter we might as well just ...do it!
Oh and the mathematics of cascaded COP+1 systems … well if you remember right back at the start of the thread I asked you to consider the “magnetic pendulum” that principle was turned into a machine … and the machine then cascaded …with huge energy gains which as you would expect follow one of natures entrenched natural patterns … given that this patten is linear the efficiency required of the “prime mover” can be extrapolated back to the origin of a COP +1 system
It now becomes obvious why such extra ordinary measures are taken to remove every possible unnecessary consumption of real power . Every Milli watt costs very dearly.
It also tells you why Randy .. if your motor starts running at all on “real power” you may as well chuck the towel in right there.
So this cascaded system …. Its on copyrighted constructional papers … so I'll go back over the last couple of pages and see who's sticking with this and contributing … I'll host the pages and PM the links to you .. this was obviously a mechanical system converted to electrical use .. however its the progression of advantage I would like you to note … stage to stage
Ps ... If'n you like things tesla ewiz ... try this interesting but some what different take on the guy
https://vimeo.com/19577546
