electricity multiplier
  • electricity multiplier
    Free energy is so simple that we have overlooked it.
    This free-energy device is based on the extremely simple multiplication of rotations
    that you get by putting a very large and very small pulley within the same belt, rope, or even elastic.
    You could also gain another multiplication factor by adding additional small pulleys attached to generators on the same belt, rope.
    A diagram of how this works is at
    http://free-energy.yolasite.com/
    Remember, with electricity, multiplication of rotations means multiplication of electricity.
    please, have enough faith to try this, and I can garantee you that you will be extremely pleased
    with the resulting multiplication factor of this device
    just think of this with the greatest simplicity
    a mini-pulley will spin around tens to hundreds of times as many times
    and rotations equals electricity when it comes to AC generators
    please think ahead a little
    I got this from God and His Bible
    it was mention as the workings of a chariot, (flying saucer)
    so the end results of doing experaments with this
    could result in learning how anti-gravity works
    or whatever way they have of getting these mechanisms to fly
    now, no promises on us figuring out how this works as anti-gravity
    but, wouldn't it be greatjust to be able to experament with this technology
    Do you think a gearbox is a free energy machine?
      · FEM = Free Electricity Multiplier yolasite.co...
      I come to you with the greatest gift that I have ever been given.
      This gift is something that we are in great need of with our power hungry public
      After seeing this contraption work, you will not understand how it has been found before. The reason is because this super-simple technology has been
      hidden by evil forces
      They use many tactics to remove this thought from your thoughts
      - They might only have to bring a vision of something that you crave
      - For others, they might have to continue using many temptations before the person looses it
      - They might even, for the determined ones, use threats and warnings
      - That can also go the other way, and demons might offer another unique thing
      - Who knows how many people have discovered this, and then forgotten it again
      - I think that I can remember thinking of this in high school,
      ------- o and I could not truly believe that it could work
      ------- o forgetting to test my theories
      - or just fill your mind with massive amounts of seductive thoughts and visions
      -------- o until we forget about it.
      They would also send you many reasons that it could never work
      - Just show somebody a diagram of this,
      -------- o + just see all of the massive negative comments
      If you think about it with an open mind, this cant help but produce unlimited power
      - If you consider the geometric principals of how you only need to put enough power into the drive DC motor to rotate the drive motor,(with the large pulleys attached) one single time
      --------- o And you can rotate your output generators, (you can have unlimited number of them) hundreds of times
      ................... § Each rotation of the generator produces electricity
      · So hundreds of rotations produces plenty of electricity
      - Each of these generators can produce a multiple of power output
      --------- o So, the more generators that you attach, the more of a
      multiplication factor you can get out of your free energy multiplier
      · I will try and paint a simple picture of how this works
      You only need to use a set amount of energy to power the DC drive motor
      - Then the rest of the electricity that you get as an excess can
      --------- o You can get far more electricity as an output
      DIAGRAM OF FREE ENERGY MULTIPLIER is at
      yolasite.co...
      To be used as a power supply
      - In varrious sizes, from microscopic to large scale power stations
      - This would start a manufacturing explosion
      § To replace all battery operated devices, making self powered
        @joe_born_again:
        I appreciate your attitude.
        However, can you show us photos and accurate measurements from a working device?
        I don't believe it can be done. By simply comparing the impossibility of powering an over-the-road semi truck with a lawnmower engine. The little lawnmower engine and the big diesel can both run at about 1,500 RPMs. But it is very easy to see that the lawnmower engine WILL NOT PRODUCE the work that the big diesel will. And it takes additional "fuel" to produce that work from the diesel.
        The same is true for your electric-motor. When it gets "loaded" with the additional generators/alternators it WILL take more electrical energy to drive that same motor than when it is "free-wheeling". . .
        truesearch
          This free-energy device is based on the extremely simple multiples of rotations
          With electricity, multiplication of rotations means multiplication of electricity.
          Believe me, I found this extremely hard to believe in myself,,,,,,,,,, IMPOSIBLE.
          I figured that if it were really that simple, then why didn’t come out long ago.
          Because of the efforts of that crafty Satan and all of his evil cohorts, 1/3 fallen angels
          This is a major conspiracy work by fallen angels and sadly deceived misguided humans
          This is soooooooooooo simple, there is no digital trickery with electronic.
          You are using the massive geometric differences of pulley sizes to multiply your rotations
          = thereby multiplying your power.
          It is really just that simple,,,,,,,,,,
          JUST BELIEVE + BUILD IT
          This is a Miracle from God, and yes, it seems to defy thermodynamics.
          It does this by using the extreme circumferential size differences in the pulleys.
          Just think about it, if you only have to put the energy enough to turn the drive motor once,
          and by adding multiple mini-pulleys with generators on them hundreds of rotations.
          YOU MUST GAIN ELECTRICAL POWER
          We can let God worry about the details of what about torque
          Just try this. And I promise you that it will work
          it works on multiplying the rotations of pulleys
          and with electricity, more rotations means more electricity
          it is really that simple guys
          FREE ENERGY IS HERE
          now lets have many people working on free energy power supplies
            Hi folks, Hi joe, posted this at O.U. site also.
            People could start with something like this and then run tests and then if it works, the pedal power could be removed and a motor replacing it to create the feedback loop (self runner).
            Uploaded with ImageShack.us
            peace love light
            tyson
              Real Power
              I don't know if this design is an electricity multiplier, but it does pull up a charge from Earth ground.
              Input power is about 20 mA.
              Output power is who knows?
              One could say that there are two circuits at play here. The radiant collector and the radiant exciter.
              The radiant exciter has the purpose of radiantly exciting the batteries, of which there are two.
              The circuit is called a Brovin Kacher Radiant Exciter.
              The circuit for the radiant collector is called a Tesla Radiant Collector.
              Basic Schematic:
              The input to the radiant exciter circuit is about 20mA; however, the radiant collector is not directly connected to the batteries. Output from the radiant collector circuit can be seen to be considerably more than the input to the exciter circuit.
              More Detailed
              Replication #1
              HTML Code:
              http://youtu.be/2JxunfyhtFI
              Replication #2
              HTML Code:
              http://youtu.be/vnHTtpPvsTQ
              Replication #3
              Diodes for Replication #3
              HTML Code:
              http://youtu.be/nhbtOvNLnko
              These diodes cost about $30US each.
              Berg
                Yes, this kind of devices seems possible, but it must resemble rather a grounded plate with elevated discharger. There is a way to "spin" electrons by EM force from ground and discharge them into air , then it works like a pump.
                  Hi berg, thanks for sharing, have you tried that setup, looks promising.
                  Had an idea about a small test model for this idea of yours joe_born_again.
                  Chas Campbell's device seems similar to what you are doing joe and same the Wilson wheel.
                  Though your design, the motor has a very large pulley, whereas these other setups have a smaller pulley on motor to start with and gradually step up the speed through the pulley ratios and flywheel mass.
                  Does your setup require that large motor flywheel to have large flywheel mass also?
                  Idea is to make a small test model that would rest on a table, that is cheap to build and try and observe any effects.
                  Can say this for sure, built a setup in the past that used a vinyl music album and this had metal can lids glued on both sides, toward the edges.
                  This was powered by a 7.2 volt rc car motor and the flywheel effect was very obvious for such a light weight flywheel.
                  After power turned off, it kept the rc car motor rotating for some time after, even though this rc motor has lots of cogging and drag.
                  peace love light
                  tyson
                    Yes.....hmmm
                      And here is a picture of that vinyl album flywheel built awhile ago.
                      peace love light
                      tyson
                        SEARCH "free-energy" + "yolasite.com"
                        FREE ENERGY IS HERE
                        I love my Father
                        He teaches me all that I ask
                        I hope that I maybe able to shake up this world
                        I want to dissolve this evolution fairytale
                        I would like to know how these scientists explain
                        how does our moon remain in orbit
                        with the constant addition of space dust
                        we do not hear much about space not being empty
                        but it contains a stead stream of dust particals
                        messing up the trejectory of its orbit
                        http://beliefstoliveby.yolasite.com/
                          Hi joe_born_again, thanks for sharing the copy and pasted information again, though if you are a real human being, could you please post something recent so we know you have a heart beat, thanks.
                          Otherwise, still think there is something to this, based on other similar claims.
                          peace love light
                          tyson
                          • #14
                            Diameter
                            Hi Tyson, what are the sizes of the other pulleys, the ones with the 5' , 2" thick wooden flywheel.
                            Once that starts to spin ,it would require little input.
                            I've been thinking of building such a device.
                            but with only one generator ...artv
                            • #15
                              Hi shylo, do not know, have not found much detailed information about that setup, other than it seems to corroborate other claims, including the one that started this thread.
                              Though based on this drawing, they look a little smaller than drive motor pulley.
                              peace love light
                              tyson
