Translation Request
  • Translation Request
    I believe the language is Russian. I would appreciate it if somebody who can speak Russian would translate the audio of this video:
    Гость УСТАНОВКА - YouTube
    Here is my impression of the circuit.
    Schematic of the Complete Circuit:
    Schematic of the Special Coil Circuit.
    Berg,
    You could ask Jetijs, he is real good with translations as well as devices.
    IndianaBoys
      Originally posted by IndianaBoys View Post
      Berg,
      IndianaBoys
      Thanks, IndianaBoys. I appreciate that.
        Request to Jetijs
        This is a request to Jetijs.
        Would you please translate the audio on this video for all of us on this forum?
        Kindest regards,
        Berg
          Requesting Comments on this Schematic
          Legend:
          A. Positive lead from the Flyback Transformer.
          B. Negative lead from the Flyback Transformer.
          C. Primary-side Capacitor.
          E. (Not Labeled) Primary HV Coil Lead in the picture.
          F. Secondary-side Capacitor.
          G. Spark Gap.
          H. Earth Ground.
          I. Lead to Second LV Secondary Coil (Diagram)
          (But in the image (picture) the Lable I. is on the lead
          to the Primary Coil.)
          J. Lead from First LV Secondary Coil to HV Secondary Coil.
          K. Lead from First LV Secondary Coil to Output (to Load).
          L. Lead from Second LV Secondary Coil to Output (to Load).
          N. Slotted Metal Tube.
          I would appreciate any comments on this schematic or device.
            Hi Berg,
            You got it.
            You might want to private message Jetijs in case he has not seen or been checking in.
            IndianaBoys
              Hi Berg,
              You got it.
              IndianaBoys
              Thanks, I'll give it a try.
              ... Done ...
                Series Resonance Device v1.1
                Here's an update on the device.
                Video: Гость УСТАНОВКА - YouTube
                  Super Simple Inverter
                  If someone would care to build this device, here is a schematic of a super simple inverter that can probably be used, instead.
                    Inverter Circuit in the SRD v1.1
                    Here's the inverter circuit in the SRD v1.1 & 1.0
                    Electronics Circuit::
                      Nice, but why there are diodes in last circuit ?
                        What is the Function of the Diodes in the Inverter
                        If you're talking about the diodes in the inverter, as far as I know, that is, I believe they protect the transistors from transient inductive spikes when the magnetic field collapses on either one of the primary coils when power to that particular coil is turned off. The energy from the transient inductive spikes is then dissipated by the resisters in series with the diodes.
                        Theoretically, you could replace those resisters with caps and take the energy off of them later, like a regenerative snubber circuit, similarly to an imhoptep circuit.
                        The circuit shown below illustrates how to charge up a cap from transient inductive spikes from an inductor's magnetic field repetitively collapsing:
                        By the way, this SRD device is being talked about at
                        TK Replicates
                          Found Russian Schematic of SRD
                          This is their schematic. As far as I can tell, it's close to the schematic I drew.
                          See full sized image of schematic.
                          L4
                          • #14
                            Schematic Examination by ION
                            Some possible details about the device:
                            Examining the schematic, key points are:
                            A pulsating DC driven very small, therefore high frequency spark gap exciting a three turn copper tubing primary (L1).
                            A bifilar (L2, L3) secondary of 80 turns each. Note since these have the same phase there should be a net zero voltage into the output transformer.
                            Another coil L4 which is in series with L3 and grounded by 0.5uF 750 volt capacitor.
                            This would seem to be reminiscent of Spheric's bifilar L2, L3, plus delay element L4.
                            Source: ION
                            • #15
                              Yes author in video speaking about this scheatic and say, that about 80 turns. Author post this video on Apri 1, and after some time delete it, but one body copy this video.
                              In russian forum ask him or it joke, but he not answer to question.
