Reduce Energy Usage
  • Reduce Energy Usage
    The most difficult day of every month is when time comes to pay bills and mostly the enormous electricity bills that we get. It’s high time and we need to take serious measures to reduce the power bill. Do not worry. We will share some key tips and will make you reach your goal.
    Make sure to discuss with family member about the importance of saving electricity. You can reward them a treat if their participation has led to savings. Suggest them some tips like switching of the lights when they are not present there and attending a call in another room or having dinner at the dining table.
    Make sure to switch off all the appliances even if you are sure to be back in five minutes. Yes, that will help a lot. Every drop of water makes an ocean.
    We may prefer to switch off the television set or turn off the fan, but not the tube-light.We need light at the time of night but see that the usage is required in all the rooms or not.Taking care of such these small precautions will surely leads us to savings in the long run by reducing the bills of the power demon.
    One should plan to invest smartly on power. Replace all the incandescent bulbs present in the house with compact fluorescent light or those CFL bulbs. These bulbs consume less electricity as they consume less power.
    Buy the energy saver gadgets that are available in the market. Such gadgets will monitor the intake of the entire power supply in your house and makes you take decision on how to control the usage.
    Most of us assume on the fact that the rise in electricity bill is due to the vast number of electrical items present at home. But the truth is that the electricity bill is not directly connected or affected due to the number of gadgets, but by the way one uses them.
    Take a step forward to avoid using those typical items regularly that consumes lot of power -
    • The washing machine should be used only when there is a bucket full of clothes.
    • The geyser should not be kept on for maximum amount of time.
    • The air-conditioner should be kept at minimum high or low temperature.
    • Take note to switch off the computer monitor when not in use. It consumes maximum power and it just takes a second to switch it again.
    Lastly we suggest that for reducing the electricity bill by taking benefit of reading the energy saving guide like Earth4Energy that has some of the best solutions to generate energy at home and providing free electricity to some of your home appliances.
    In this way we can save power that is facing a huge shortage because of the large demand in the global countries. Try to reduce the requirement of those electrical wires and sockets for home and use the renewable energy extracted from natural resources like wind, sun, tides at a lesser price but having a long term returns.
    Make power at home
    with solar and wind energy to eliminate your power bill. Get our complete guide at www.earth4energy.com
    Learn The Top 7 Ways To Reduce Your Electric Bill
    and Save Up To $800 Every Year.
    GET The FREE Report Here!
    9 tips for reducing power usage in your business...
    Hi, guys. Jut thought I'd share with you some more tips on energy conservation. Saving power can be one of the simplest ways of improving the profitability of your business. You can make quick power saving changes across your business that will reduce your energy bills, lessen carbon pollution and conserve energy. By also training your staff on energy saving, together you can do your bit for the environment.
    The more energy you save, the more profitable your business can be.
    Here are 10 great ways to start:
    1. Keep control of your heating & cooling
    By simply reducing the heating temperatures in your business by one degree in winter can cut your heating bill by up to 8%. If possible, open up the blinds or curtains on a sunny day and turn the heater off.
    In warmer months, setting your air conditioner’s temperature just one degree higher than usual can reduce the power it uses by up to 10%. Positioning thermostats away from draughts and direct sunlight ensures they are accurate.
    2. Avoid wastage
    You can save up to 75% of total heat loss by closing doors to colder rooms on cooler days, and closing doors to warmer rooms on hotter days. Fitting draught excluders and making sure your premises are well insulated can be very cost effective. Keeping doors and windows closed when heating or air conditioning is running will also save on costs.
    3. Minimise artificial lighting & replace existing lighting with a more efficient option
    By having the windows and skylights clean, you can cut the amount you spend on lighting. If you are working in one part of a room, isolate the lights to that area only. Label switches so your staff only turn on the lights they need, and turn them off completely at the end of a working day. You could also consider installing presence and daylight sensors to turn the lights on and off automatically.
    Switch your existing lighting to a more efficient lighting system - there are plenty of options available, and the annual savings are considerable.
    4. Use energy saving features
    Most electronic office equipment such as printers and photocopiers have energy saving capabilities. Train your staff on how to use these features.
    5. Switch off office equipment when not in use
    A single computer and monitor left on 24 hours a day can cost over $200 a year. Switching it off after hours will conserve energy and reduce your energy bill. You could also fit seven-day timers to ensure equipment like printers and photocopiers are turned off overnight and on weekends.
    Energy star computers with a sleep mode consume up to 80% less energy than conventional computers, with laptops up to 90%. Setting PCs to go into sleep mode when not in use can save up to 70% of the energy they consume when in full power mode.
    6. Make sure your equipment & systems are well maintained
    A properly maintained heating and cooling system should work more efficiently than one that is not maintained. This should save energy and running costs.
    7. Out with the old…update your heating and cooling systems
    If your old air conditioner or heater is not working at maximum efficiency, it could cost you money and use a lot of unnecessary power. By replacing air conditioners and heaters that are more than 10 years old, you can save up to 40% of your annual heating and cooling energy costs.
    8. Invest well
    When purchasing PCs, monitors, printers, fax machines and copiers, consider ENERGY STAR© models that power down after a user-specified period of inactivity. If appropriate, use inkjet printers - they consume 90% less energy than laser printers. Purchase appropriately sized copiers for your business’s needs. Look for the energy rating label External link when purchasing new appliances and equipment – the more stars the better.
    9. Get your staff involved in the effort to save power
    Create an energy efficient work culture in your business. Saving energy will require your employees to take on some of the responsibility, so make sure to consult them before changing your practises, and ensure everyone is on board in the effort to reduce power usage.
    I hope you find these useful.
