There are supplements (zinc) given to deficient adolescents who are not maturing or growing much and they grow much more after. But they don't continue to grow at that same rate if continued on the supplement, they just make up for the deficient state then level off. Maybe the chickens who drink this radio water are the same? But who knows, I will be interested in slider's experiment, maybe after one year of radio treated water, I will be drafted first round by the Phoenix Suns, and I can stop this job hunting.
Water treated with radio waves
A study in japan where oysters raised near the rivers shrunk in years due to inuded forest.... so they planted trees and after 3 years the sea oysters get their nutrients and had grown 10 times .....
Also , its in the food chain Mcdonalds and junk food are for the middle class before thats why batch of 60s to 65s did not grow taller...... but now batch 80s (born) were taller than their sis and bros......
thanks to the junk food .......
It is fairly simple to get started with 27 MHz.
circuits for crystal based 27 MHz signals can be found in
inexpensive remote toys and handheld cb radios.
an 11 meter radio using one tube were available long ago. I believe the high voltage would be valuable inside a resonating cylinder and introducing a very small amount of water so that the chamber has alot of atmosphere, maybe a little diesel also. The tube should be made to deaden spurious radio noise.
I believe the equipment should resonate to the frequency rather than searching for one particular frequency. The study of plasma or plasma reformers reports that a catalyst further enhances the COP even higher. Not science fiction.
Measure the output with enhanced gas mixture to power a turbine that turns a generator
on constant load over time. There are 2 ways to fight the debunkers.
Show that the enhanced gas mixture is not weak as people are lead to believe but can be powerful.
second, show how clean the output is compared to a modern automobile exaust.Last edited by mikrovolt; 09-05-2013, 07:29 AM.
Originally posted by mikrovolt View PostIt is fairly simple to get started with 27 MHz.
Ancient Secrets Of Clay Amphora Vessels - YouTube
Clay helps to shape high temperature supercapacitor | News | The Engineer
Scientists Demonstrate Ultra-Fast Magnetite Electrical Switch | News & Opinion | PCMag.com
“Signs and symbols rule the world, not words nor laws.” -Confucius.
Interesting feedback.
The umpqua evopak is the plasma reformer (mit fuel reformer) I refered to.
The pdf needs copy archive please:
http://www.ghp-books.com/freegas/plasmatron1.pdf
The ultrafast magnatite clay reformed lends itself to conditioning.
The farnsworth shelved tubes (multipactor and canal )had a phenomena glow forming a space charge called plasmoid or small star.
The Farnsworth Fusor
I did research on a simular devise which has been taken from public knowledge. It was a specialized television tube.
What was taught about magnetism was this:
How Magnets Produce Electricity 1954 US Navy Electromagnetism Prime - YouTube
both cold and hot fusion have not been taught well and many devises have disappeared. Television was was clearly given priority but why.
"Extensively tested in Warrenstown Agricultural College, the technology is being hailed as a modern day miracle."
Taken from the article.
Interesting, the college was closed in 2001. It was bought out in 2008 and houses Colaiste na bhfiann, an Irish Language College. Quick check on Wiki showed that.
So this highly likely scam needs to sort out its 'facts' a bit better to obfuscate where the supposed tech comes from.
Sorry guys, it most likely is false.
Bifurcation transitions in a photochemical system under low magnetic fields | Browse - Journal of Chemical Physics
This is probably a good place to start. I think, I'm at home so I don't have access to lots of research articles. I work at a Uni, as a lowly senior lab tech, which means I know how to get things to work in the real world, unlike the big academics who know how things should work heheheh.
Anyway, whilst there may be evidence that EMF can promote (or stunt I would assume) plant growth there OP reference seems like a dud mainly because it cites an institute that no longer exists, unless wiki is wrong, which it has been known to be.
Electrical stimulation of plants to enhance growth or resist disease has been
around since the turn of the century I think or before. I think there is a
thread here about it.
Would it really matter how or where the water is treated by electricity.
From memory the old method was to erect atmospheric potential harvesters
or radiant energy receivers to power wires buried in the ground and with
seemingly very good results, the energy is free and not high tech anyone can
do it. It is also well tested and would seem to be a proven technology.
Is anyone going to try that method ?
I might. I might just grow two plots of a crop, but to isolate the control crop I
would need to use above ground pots for it or locate the control crop at a
distance which will have other effects, so the crop type is limited. A crop with
lots of individual plants so there is more data would be better than testing
three or four tomato plants.
Maybe Slider is willing the plants to grow better and they are responding to
his thought energy.
I also have an electric fence outputting HV impulses about every 1.5 seconds
which I can see on my scope from 100 meters away if I scope the ground and
a piece of isolated metal. So that would affect a ground crop as well maybe.
CheersLast edited by Farmhand; 09-10-2013, 09:14 AM.
for those who are interested :
OSnano
Open Source Nanotechnology
Open Source Nano is an invitation to participate in the innovations of nanotechnology right from the start. It is an experiment in making high-tech laboratory research something that can be improved and innovated outside the laboratory, by making it “vernacular”–putting it in the language that people speak, and the tools and materials they have at hand.
At this stage, it consists of only one project: instructions for creating magnetite nanocrystals; but we hope this project will inspire others in the future. What can you do with magnetite nanocrystals?
Why? Magnetite Nanocrystals are good for removing arsenic from water. Based on recent advances in nanotechnology, it’s now possible to make regular magnetite nanocrystals as small as 20-100nm, and to remove them from solution using a handheld magnet. Arsenic poisoning is a huge problem in Southeast Asia, especially in Bangladesh, and in various other parts of the world. Our project opens up the process for making magnetite and encourages you to experiment with it, contribute to it, and improve it.
Originally posted by MonsieurM View Post“Signs and symbols rule the world, not words nor laws.” -Confucius.
