Hi all,
Some time ago, I posted a thread at Russ Griess' site about the theoretic principles along which Stan's system is capable of drawing excess energy out of the aether/vacuum/ZPE field/whatever name you prefer:
Theoretic foundation: the electret effect
And I posted a YouTube video about this, wherein I explain the principles:
How Stan Meyer's "Car on Water" as well as "Cold Fusion" actually works. - YouTube
Since the idea is that the WFC is supposed to be an electrolytic capacitor, I went looking for ways to make a suitable dielectric layer on top of stainless steel. The first direction I thought of was some kind of nickel oxide, because stainless 316 has the highest concentration of nickel, and nickel is also being used in super capacitors. However, these use a different mechanism and are thus NOT suitable in a normal electrolytic capacitor like the WFC.
So, I went looking for what I could find out about chromium oxide, and more particular, Cr3O2, which is the oxide growing on top of stainless and which is what protects the metal from rusting.
It turns out that Cr3O2 has similar properties as aluminum oxide, which is being used in electrolytic capacitors. It has a dielectric constant comparable to aluminum oxide and it has a high ohmic resistance, i.e. is an insulator (at room temperature).
AND it turns out that so called "electropolishing" process which is used a/o for passivating stainless steel for medical applications is very similar to the process by which normal electrolytic capacitors are made, which are mostly based on aluminum.
See my posts over there for more details:
Now if we add one and one together, I would say chances are very heigh that Stan used electropolished stainless steel.
That basically explains why Stan did not appear to have "conditioned" his pipes, but others reported good result with "conditioned" pipes. So, he apparently *did* use a specific "conditioning" process, BUT he simply just ordered "electropolished" stainless instead of doing it the hard way...
Some more info on electropolishing:
Electropolishing - Wikipedia, the free encyclopedia
http://www.tuks.nl/pdf/Reference_Mat...l-implants.pdf
http://www.globalstainlesstechnology...le_9-27-99.PDF
http://www.euro-inox.org/pdf/map/Ele...lishing_EN.pdf
