Use the Force Luke ... Use the Force!
  • #61
    Originally posted by OrionLightShip View Post
    Sorry Orion Blocked in this country!
    • #62
      Seriously? They block youtube videos in Britain? Wow, we really have fallen down the slippery slope of tyranny on this planet. Will they come get me if I convert it and send an email?
      @Steve Ward
      Would you please make a video showing how you make a thermometer stop working?
      Would you please share with us how you create gravity or at least tell us what it is. 7 billion people on the planet would be most grateful and since you are the only other person who understands....perhaps you could share with the rest of us unworthy, less educated humans.
      I went to the trouble of installing real player to watch your "presentation", and I watched your videos on youtube. I am so stupid that I am unable to grasp the smallest thing from them. I did get some insight into how you work. I'm sure you are a wonderful person, who like me, struggles with communication skills. I wish you luck and success.
      • #63
        Duncan, can't you use a proxy or VPN for that? Couple excellent ones are Security Kiss and Spotflux. Both free. Security Kiss is limited to 300 MB per day unless you pay. Spotflux is unlimited free.
        SecurityKISS - Free VPN Service
        Spotflux Free VPN
        • #64
          Steve,
          I don't know if you remember me, but we talked on the phone a long time back. I still have your cell number, as well as your email address (at least the old one from 7/19/2011) and could call you if you would rather. I have followed your progress with interest for a while now..
          Please understand that right now you have the interest of a lot of folks, but so many frauds have cone on these forums that people are very skeptical. They have to see it for themselves to believe it, and right now I don't think anyone here understands what you are doing well enough to do a simple experiment so they can see for themselves what you are talking about.
          Is there a small experiment you could walk us through step by step so we can all do it and see exactly what it is you want us to see? I believe that would really help. And once people UNDERSTAND, most of the negative stuff will vanish.
          Of course you will ALWAYS have some folks that insist that what you claim is not real, but we know what to do about them don't we? IGNORE them.
          By the way, I don't know whether you remember this or not, but I am in San Jose, CA, and have access to some serious venture capitalists if you have a working prototype. When we last spoke, you were working on one but needed funding. I will be doing a demo of a prototype of my own in the next few weeks and the outcome could be a check with lots of zeroes. If you are still in need of funding, search your emails for my name..David Bowling, and you have my email address and phone number from our previous communications. Right now, through the contacts I've made with some mainstream folks, I have pretty much unlimited resources (within reason of course) for prototype development. And since you have a patent, you are fairly safe.
          • #65
            Steve,
            It's been a while since I watched your videos, so I went back just now and watched them again. Please correct any incorrect statements I make here, as I try to explain what I see, and what I believe you are trying to demonstrate and tell us.
            In one of your videos you show a DC motor run by a power supply which is turning a magnet past a coil at a certain rpm. When you short across the coil the motor slows down and the amp draw from the power supply increases.
            Next, you increase the RPM at which the motor is turning the rotor. At that higher RPM you short out the same coil again. Only THIS time there is an increase of RPM's of the motor (instead of a slow down) and a decrease in the amps drawn from the power supply (instead of an increase).
            The only variable that was changed was the speed at which the motor was run (which does affect the amp draw from the power supply).
            Is this an accurate representation of what is happening in the video, what you want us to see, and an explanation of how you believe "Wardforce" is affecting the electric motor?
            If Wardforce is doing something other than what I have described here, please correct me.
            • #66
              Saw something similar months ago
              "The Angus Effect" 2 Re: Jay Braun - YouTube
              Enjoy
              • #67
                Ruphus,
                Thaine Heinz and others have shown this is possible. And doesn't Thaine have a patent? And I would argue that Steve Ward, if he is trying to show us what I THINK he is trying to show us, is absolutely right. Basically the same cat skinned a little differently. And he has a patent also??
                But, as with the video you posted, look at the KIND of loads (Resistive Loads) they are able to run with this setup. What happens when you try to run an Inductive load? Not QUITE so easy. What happens when you hook the output to a bridge rectifier and try to run some loads off THAT output?
                You notice Steve Ward is shorting across his coil to show us that he has something. What happens if you hook inductive loads to that coil, or rather to a bridge rectifier connected to that coil?
                It not as easy as it appears in these videos...unless all you ever want to do is run some lights with the setup. But as a starting point...well worth the time to begin an investigation.
                • #68
                  patent
                  Hi Steve, in patent# 7531930, pg3, of 5. is there where you cancel the magnetic fields?
                  I believe this has great merit.
                  If you put a strong enough field to a weaker same pole ,you can reverse its' polarity field.
                  If you hang a thin piece of steel off of a magnet, which has the stronger pole? The end touching the steel or , the furthest point away?
                  Can the collapsing field induce secondary windings?
                  I find this stuff fascinating...........more questions than answers.
                  artv
                  • #69
                    Me telling you is not working, let me show you.
                    @Steve Ward
                    I hope you understand, a list of materials needed, where they can be purchased, drawings, US Patent # and more on my website for FREE to everyone in the world. Sure I need help paying for all this, which I have and keep doing.
                    A Patent is nothing more than a blue print of what and how you are doing it. How much more do I need to give? I have spent thousands of Dollars (US Patent, research, prototypes...), a life time trying to show this to YOU and YOUR children. The point is, in simple English, Wardforce is not a Pole. I GIVE on my website everything, telling how and what. I am not trying to be mean. Spending much still for the websites, travel (I have changed nothing), I can go on and on about my expenses. The point is, I have done this so that OUR future (our children) will have a better understanding of cause and effect. Allowing them to make better choices, hopefully.
                    Steve Ward
                    • #70
                      Steve Ward
                      Ok,did you considered wardforce could be outside force ?
                      • #71
                        Originally posted by GSM View Post
                        You would not be here were it not for your prior discovery - and is it not the discovery which really counts - not the words !
                        When Duncan introduced this topic I wrote -
                        "The provided 'explanation' here is something I simply cannot understand as expressed."
                        this being where my mind still is - not understanding. But I shall.
                        Understanding ? Concepts ? Words ? So many concepts within physics can be described in different ways, and though some are not correct, they do at least provide a workable understanding.
                        So I thank you for that lead:
                        I will most definitely check it out later today, for there is clearly something here you feel a real need to share and get sorted !
                        Yes, our Earth has both poles - due to spin - and the apparent polarity relates to a steadily rotating angular rotation in space, with that spin having different identity if observed from opposite axis ends !
                        Magnets also simultaneously have two poles due to one internal electron spin-orbits alignment (atomically related) throughout its own body. However electron orbits are precessive, and not as purely simplistic and one way alignments as are the bar magnets they are capable of constituting.
                        Similarly, soft iron can be induced to have both poles as internal electron orbits become aligned by a magnet or field coil, and there is only one rotational alignment through the body of the iron.
                        However, spinning or vibrating soft iron in relation to the speed of its own magnetic precession characteristics (remanence), can induce it to undergo an additional 'free' polarity reversal within the induction time period mechanically provided by the equipment, where the magnet to iron magnetisation gap can be adjusted to alternate between series and parallel field induction.
                        That 'free' intermediate alternating field reversal (electron orbit precession), cyclically arising via the timed (tuned) series-parallel 'charging' of soft iron by a permanent magnet, is as field coil transducible from its core, as would be a capacitor's discharge output when cyclically charged from a 'permanent battery'. And of course the primary field used to induce reversal could itself be from an energised field coil too, though then I would wonder about the COP.
                        Do any of these words apply to your equipment, and have you arranged its output to be full cycle pulsing per single polar alignment, or double cycle outputing (quad amplitude rectifiable) per single rotation ?
                        Cheers ................ Graham.
                        First, a Magnetic Field is a Magnetic Field. Rather it be electro-Magnet, Rare Magnet, Earth, another planet or what that it is caused from.
                        Second, Wardforce, named after years of people asking what it was called, was named this because it is a FORCE and it controls forWARD and backWARD motion.
                        Last of all, if I tell you, there will be questions. If I show you and we build something, you will know. No questions, because you know how it was built, put together and what it is doing. Well honestly, there will be questions, just not as many, if I show you.
                        Don't you think that your children should know about Wardforce? Part of the Magnetic Field that is not a Pole at all. How do you think I cause energy, torque and current, while moving the shaft back and forth, not in a circle? What is changing in these Galileo Thermometers? What...? Why...? What do you think your child could discover if they knew that we don't know everything.
                        • #72
                          Call me
                          Steve,
                          Dave,
                          Call me on my cell phone, I have many prototypes.
                          Steve
                          • #73
                            Energy-Ingenuity.com reply to GSM.
                            A magnetic field has no effect until its field effect is induced within matter by acting upon electron orbits capable of aligning with the electron orbits of the matter constituting the magnet !
                            This is why we do not 'feel' the force of a magnetic field, even 1T+ fields as in an MRI machine, inducing electron orbits of our atoms to become directionally aligned, with the recorded image relating to different spin orbit recovery time periods within our bodies for different elements.
                            ALL magnetic attraction and repulsion FORCE relates to the cumulative effect of electron orbits within atomic matrixes at any given time inside bodies of matter having same or opposite angularly aligned electron spin-orbit senses respectively.
                            Charges flowing/ spinning in the same direction attract; opposites within any body neutralise field; opposites externally cause field induced repulsion.
                            However, field directions (electron spin-orbits) can momentarily or permanently be induced to reverse within soft iron, and this reversal can be used to transfer or transduce magnetic induction.
                            This field reversal within iron can be accomplished by physical movement of its position with respect to a magnet (Wesley Gary ~1879), or by an additional electrical impulse superimposed upon an otherwise established magnetic field (Hubbard ~1919; Hendershot ~1928).
                            Please clearly define what you perceive the fundamentals of "WARDFORCE" to be ?
                            Whatever it is you believe you have found and demonstrated via your equipments and videos is not clear, therefore I cannot know whether any children should know. Videos may be better via DailyMotion.
                            Magnetism is an electron spin-axis related field effect between atoms.
                            Like spins attract - they cause magnetostriction.
                            This might cause a thermometer to read low without temperature change ? Is this what you show ?
                            What is physically moving within your equipment ? And with respect to what else ?
                            It actually looks as if your Patents were written in a manner designed to preserve your secret, which makes sharing more difficult without either open demonstration and explanation !
                            Cheers ................. Graham.
                            • #74
                              To Steve
                              Hi , I visited your site and need to reread your patent.
                              When you induce flow in a coil, the coil almost instantaneously creates an opposite force.
                              That is by inducing flow creates a magnetic field, then almost at the same time an opposite field appears.
                              Before this opposite field can come to being , is this where the interruption is activated?
                              Also when you stop the induced flow in a coil , an opposite field appears again , this time it is what you originally created in the first place.
                              Is that the sweet spot?
                              Between applying source , and cutting it off before the opposite reaction occurs?
                              Great stuff.
                              artv
                              • #75
                                Permanent magnet generator with no relative motion between magnet and coil - YouTube
