Hi everyone,
you may have read that I've been saying this circuit is not creating energy. What I think is going on in this circuit is by causing a time delay between the TWO electricity components (voltage & current) you don't destroy the electricity (aka don't kill the dipole) by short circuit like typical everyday circuit we use.
When the electricity components are 90 degrees out of phase they can go through a circuit, do work and come back out with next to no losses if there is minimal resistance in the circuit.
However, you need something to receive the return and store it or convert it to something useful. I think this is what the Alternator Gen is doing. So timing is very important and I'm now starting to think that a permanent magnet alternator gen may not work as well as an exciter rotor field alternator gen like I've been using in my demos.
Let me explain, for the past 3 days I've been busy converting a DC permanent magnet motor to an AC permanent magnet generator. It's a big job but I got it done and I was testing it last night and found the effect is not as obvious or as good as using an exciter field rotor generator.
When my series cap circuit is connected to this PM AC gen it's like something is out of timing!... I see the effect a little but it's like it's kind of having a fight inside the gen, like a motor out of timing. So I'm starting to think that the exciter rotor gen causes more of a delay then a PM gen and it could be this delay that makes the difference in helping the gen rotor to be pushed at the right time when the reactive power is returned.
More tests need to be done but I though I would share this new information.
Luc
Also, at the OU topic, user name nilrehob has been doing a lot of experiments with what I have shared and has prepared 2 pdf documents.
Here is his post:
Hi Luc,
As You requested, since I get little time left for experimentation, I have written a short 3-page pdf about what i call "Reactive Impulse". This will be my next area of research. Maybe You (or someone else) will find this interesting and beat me to implement it.
https://sites.google.com/site/nilrehob/home/documents
/Hob
Luc
Here is his post:
Hi Luc,
/Hob
