Howdy Energeticforum.
Its been awhile since i've posted any threads or videos these days. Just pounding away slowly at things as they can either be afforded through time or money. I know most of us know how that can be.
Pretty typical stuff in the video Bedini Multi-coil SSG Runs 24/7 on Renewable Energy Nothing we haven't seen before. Actually a far more a personal look at the way I live, than a technical marvel of any sort. :P
Video description...
Using a bedini multi-coil SSG as DC pulse motor to derive greater efficiency through use as a ceiling fan. The transient (back EMF) spikes that are generated from the fast switching MJL21194 transistors, instead of being wasted as in typical DC motors, are being sent to charge a separate 12 volt battery bank. (aside from the powering 24volt solar array bank)
At the time of this video recording my power in/out levels were as follows...
INPUT (from solar charged 12 battery array) = 25.8 volts @ .91 amps for 23.478 watts
OUTPUT (to 2 battery pair) = 14 volts @ .68 amps for 9.52 watts
Heat and mechanical losses @ multi-coil SSG and fan = 13.958 watts (not bad I think)
See schematic (Bedini multi-coil SSG) @ 5:04 mins of the video.
I will be setting up Cree LED lighting which will be ran exclusively off that back EMF that charges the secondary battery bank. Watch for follow up video !
Basically i'm trying to run my inverter as little as possible as that is where there are consistent losses.
