Lets start the new year with a bang!
  • #61
    Fascinating Thread my Friend!
    Hello Duncan,
    Well, thanks so much for this Thread my Friend!...I have been reading all your texts, data and links... (not done yet, it is pretty much material there to be digested)
    Everything there makes perfect sense , from magnetic fields to electric fields to that "unknown electric flow" or Impulse Flow...I always thought there is more to Static Electricity as all we have learned in school...
    As my "Two Copper Pennies" to this Quest...one thing that I see set Us back in research and development right tooling (besides finding the right magnetic core material) is the fact of being working with Fixed Fields when it comes to be looking for an specific "sweet spot" in resonance matters.
    Nikola Tesla Patented and Developed the Adjustable Condenser...
    Later on it was used to "Tune" Radio Signals as a "Receptor" to waves in the Air... as utilized in the LC Circuits to find "Resonance Spot"
    Variable capacitor - Wikipedia, the free encyclopedia
    This guy below shows all advantages on building one and using it for those purposes:
    On the "Transmitting End" a Variable Condenser is also applied to a Sound Microphone...obtaining Directional and Poly-directional capturing.
    Variable Condenser Microphone Patent (1958)
    Unfortunately, the Mechanical adjustable capacitor has passed to an obsolete component in Radio Industry...when the digital and electronic technology came to play...however, for Lab Work on this Series or Parallel Resonance circuits...I believe it would be of great use to find the right capacitance value to enter the "back and forth" game (or could say "dance") of resonance right spot.
    But , even though we get the adjustable capacitor...I still feel we are kind of "handicapped" playing with only one side adjustment on the Static Field of the LC Circuit... Therefore I propose a kind of a "different" (could call it crazy) approach:
    What about using on the electromagnetic (Dynamic) side of the Coils Laminated Cores...a way to also "Adjust" the Magnetic Field Emitted?
    And I am NOT referring to a Variable Transformer App by changing Coils Secondary connections to output...Nor in any matter changing the windings Configuration...but, to physically change/adjust the core itself? Say Interlaced laminations, similar to the adjustable condenser body, a "Stator and a Rotor"...but this way changing the density of the core, therefore changing the magnetic field projection and varying its strength, shape and density...this will reflect back from the coils wrapped to our adjustable condenser LC loop?
    I believe if we could get a way to adjust both Fields...Static and Dynamic, Electric and Magnetic ...creating an LC Network we could be closer to find much faster our "Holy Grail" spot.
    The Geometry of Interlaced lamination of the suitable material could be expanded to almost any shape or volume...from H Frames to Toroid...wrapping segments of coils attached by flexible connectors that would be able to move between them without touching plates...maybe using oil or a liquid as a dielectric to absorb Eddy Currents...
    The thing I see as a disadvantage from the Scientific Research point...is working with static/fixed fields...we have no choice but to "R&R" (Remove and Replace) Components till we find the right match...but, what if we just discarded the wrong value in any of the ends that would have worked with a new one to be loaded?...it will be the "never ending saga" finding right combinations of values...like it has been done for decades without any luck.
    Sometimes we find that an Electric Motor of any kind...or a Generator...makes the "System" work perfect, when connecting it between a Battery and other components...like it happens with the 3BGS...wouldn't it be that we are adding "variable magnetic fields" to our already Static side...giving it the required missing "spice"?
    I also agree with you, Duncan, that in Acoustics...a Variation of the Magnetic Field exists in a Loudspeaker by a moving coil within a fixed magnetic field...and a static core as the nucleus of the cone...but what I am proposing is completely different...by changing the steel or iron or whatever material density by opening or closing the plaques or cells...and that could be arranged within a Battery type composition...or as an isolated component.
    I hope I have not caused any distraction from the main"spirit" of the Thread...as all I am trying to do is cooperate in finding a solution to our Enigma on Energy.
    Kind Regards to All, and thanks again Duncan!
    • #62
      Your welcome
      Just a bit of caution, it is bulky compared to iron. and you should use the minimum amount of binding material to get the job done as to minimize further density loss. If you think it might help you can mix it with paint and paint it over the finished coil.
      It is sold as a pigment or as a component of thermite on eBay.
      If you work with pulsed DC instead of AC you should be able to significantly push the hertz as the domains don't have to reorient themselves.
      • #63
        Light bulb!
        Looking at the variable capacitors if you need to modify them. titanium dioxide has a dielectric value higher than pure water and is a paint pigment, so you can literally spray paint it on.
        • #64
          Thank you Ufopolitics I'm delighted you are taking the time to plough through what I am considering and that it is making sense and meshing together for you. I in turn have spent a deal of time reading your thread and am aware of your work. I confess I am a little envious of your constructional abilities. To put the electrostatics into context right back to step one and the Lorentz /Einstein conspiracy and the Lorentz force law the 90deg vector the equivalent of the electromagnetic wave (the electrostatic wave) is simply missing .. gone as if it doesn’t exist . Still using the electromagnetic wave (radio) and what little information there is on the electrostatic wave (Tesla's Wireless) you can start to put the bits back in place here's a few examples .
          Radio
          Wireless
          Electromagnetic wave
          Electrostatic wave
          Parallel resonance
          Series resonance
          Sine Wave
          Impulse wave
          186000 miles/sec
          192000 miles/sec
          Demodulation typically a Crystal diode
          Cavity resonance
          in other words UFO there is another system running alongside this magnetic one .. much as radio relates to electrical engineering . It is potentially far better and easier than magnetics, Since Its direct electrostatic conversion although I don't have much of a practical route through plotted,
          and so I was reluctant to try and open a thread on it .. although Its obviously part and parcel of this It would muddy the waters here because its in a different dimension just as Radio is to electricity.
          Still you have forced my hand .. thanks a bunch guy's I opened the subject on another forum for some quiet probing I called it 'Crème de la crème' because it could be I'm Just going to have to open it here as well to avoid confusion! I suspect I'll get laughed out of court !
          • #65
            Originally posted by Duncan View Post
            what a great Idea Hrothgar .. its certainly never crossed my mind .. I'll investigate!
            And what do you think is on magnetic video tape?
            Mike
            • #66
              Mike
              Its certainly a candidate Mike I never stopped to consider the huge bandwidth of that stuff. I'm just wondering if it could be wrapped or layered and how directional it could be made .. I wonder if the magnetic goo would come off and could be moulded as suggested above with rust.
              What had you got pictured ? How about whizzing it up in a food processor then set in resin ?
              Is it worth a try or have you thought of a better way ? .. your trips to the crapper are very beneficial Michel in more ways than one .. I may well send you some Senna pods … gratis .
              • #67
                The idea was only for the iron oxide, not the tape it has a very fast change of polarity, or it would not work as a digital storage, so to say
                regards
                Mike
                • #68
                  regards
                  Mike
                  yeah I can wholeheartedly agree with all that .. but its stuck on there with some pretty solid glue isn't it?
                  I did have a scrape at a bit of video tape and didn't have much joy. Stick it in solvent .. burn .. it . Heat it what’s the master plan? There's certainly no end of old video tapes about .. I'm sure I've still got my Bob the builder collection some where . I might be prepared to sacrifice one or two of the more pedestrian episodes .
                  • #69
                    Making exotic material
                    I have be playing around making exotic material for a while now, it all came from my SMD electrolysis and being able to make graphene oxide from CO2, but it needs a through put of CO2 to make any reasonable amount, if not the only amount made is what carbon was in the electrolyte to start with in sodium acitate, not very much if you look at the formula.
                    I have made some nice copper coated graphene nano tubes by this method, here is a photo of them in solution, pretty cool if I say so myself.
                    My problem is I am like a child in a toy shop, I find one toy and then on the next shelf I see another, in the end I am trying to play with them all and getting nowhere
                    SMD also produces power and charges batteries very fast and is why it is the most effective system of electrolysis, and so the games move on from one to another as I find new things that can be done.
                    Several people have replicated the basics, but as of yet I have not shown the rest, it is all for a new topic when I think it is the right time. This is my main work for some time and has a big future I think, it is where physics and chemistry come together and don't break any laws, just unusual science
                    Mike
                    • #70
                      yeah I knew you were busy in that area mike !
                      New way of making a ferrofluid. Costs less than 3$!!! : Collect ferric oxide
                      I have an old abandoned mine walking from distance me ...
                      Cool Graphite | Borrowdale | British Geological Survey (BGS)
                      Think I should buy it ?
                      how much is that stuff an Oz ? just send me a sketch I'll soon buy all the magnetic stuff I need
                      • #71
                        I would buy it, clean out your piggy and make them an offer that they can't refuse might need the sawn off as well, just to lube them a little to the idea
                        Graphite mines all of a sudden have become big business
                        Mike
                        • #72
                          While glamourous...
                          The composition of a typical ferrofluid is about 5% magnetic solids, 10% surfactant and 85% carrier, by volume. I abandoned it for the lack of requisite density.
                          • #73
                            All F.E researchers are totally insane tptb say so .. why not me ? Its my turn!
                            Magnetic engineering is a one of the many subjects I'm woefully ignorant in I'm grateful for any input . I have been thinking about the basic operation of a simple transformer. Say wound on a closed Iron toroid for instance . I here think of how it works .. not how the books tell us it works with that cutting the coils at 90 deg rubbish .. how can it do that ? Sure you can induce flux into the Iron core but that's where it stays .. there's perhaps 1% leakage if that, its in there trapped. There is no way the flux can as the books tell us 'cut the coils at 90deg' the flux cant get anywhere near the coils never mind cut them. It can't get out of its prison, I recalled another great researcher in the field effectively destroyed by tptb and now dead Chris Carson and this demonstration of the corruption in transformer theory beginning at 6min on the first video and finishing at 2 mins into the second (just my luck to get stuck across two video's ) anyway there's a comment by EPD regarding spaceships and light and the windows I'd like you to take note of too .. so perhaps just as well.
                            Talking of capacitors this crafted machine of Chris's is what started the problems for him. direct electrostatic conversion.
                            Part 4 of 6: Eric Dollard & Chris Carson Tesla Longitudinal Wave Energy SBARC Ham Radio - YouTube
                            Part 5 of 6: Eric Dollard & Chris Carson Tesla Longitudinal Wave Energy SBARC Ham Radio - YouTube
                            now a little bit of lunacy … Its allowed I do free energy research every one who does that is a lunatic tptb and big oil say so . So lets see if some bits can be loosely slotted together
                            first lets put Tesla's luminous Aether back in place where all the giants of the time knew it should be
                            Tesla describes the Aether as acting rather like a gas in this regard I believe he meant applying equal force from every direction , feel free to view this as a ball being held under water .. the pressure on the ball is equal in all directions.
                            Tesla also informs us that energy would be available at any point in the universe . Not the planet the universe. The fact that the transverse wave does not exist in space and light is not visible in spacecraft without glass made with reflective mesh is also pointed out by EPD.
                            Edward Leedskalnin also surly built this telescope with no glass as a tongue in cheek swipe at the Michelson–Morley experiment which was supposed to prove beyond any shadow of a doubt there was no Aether.
                            Edward knew otherwise. So the Aether exists every where in the universe its omni directional, it exerts equal pressure and travels in a straight line. What then if it hits a lump Say like our beautiful planet with us on it ?
                            Why surly it passes straight though us and it . Only neutralising at the centre of the planet where forces from every vector meet and are cancelled out. This then is what Edward Leedskalnin meant when he said the magnets were holding us and everything else together . It is the luminous Aether he is referring to , another man's sea of energy , and yet another’s radiant energy still ..
                            A rose by any other name would smell as sweet (William Shakespeare - Romeo and Juliet)
                            and so as this force of life passes through everything in encounters varying degree's of resistance
                            each substance having a different impeding effect on the linear wave . This effect I suggest is what you know as gravity . And Mass being the various amounts of resistance offered by various materials to the passage of the Aether .
                            So by extension I suggest that gravity is not an attraction of one mass to another rather an external pressure pushing things down due to resistance as the luminous Aether passes through.
                            No one knows what gravity is ! Do you believe that ? These horrible bloody people have been feasting from the public purse discovering all there is to know .. a more accurate statement I suspect would be .. nobodies giving the information to the people who supplied all the money for the investigations in the first place.
                            Keep the idiots in blinkers and feed um rice! .
                            So how does this effect the transformer I was considering what seems to be quite an age ago ? Quite simple now the flux doesn't have to leave the Iron core does it?
                            It simply has to move laterally, this in turn would make the passage of the Aether easier or harder on its passage to the earth’s core..
                            If harder then the Aether is arrested temporarily in the winding and hence develops voltage and current . If easier then the normal neutral state of the substance is experienced with the linear wave passing through only hindered as normal. All the formula's bull Sh.. and waffle that have been massaged into place still hold good but the fundamental principle of operation is very different. The energy is coming directly from the Aether.
                            So now UFOpolitics comes a sticky patch .. you are quite right every step is engineered. Each piece of logic is proved and demonstrated in theory or act except this last piece here .. the reason is this I have engineered this as an electrical machine .. because I know no other way .
                            But as I think of what I have just written .. The impulse wave I suggest will not be electricity in any form I am used to … it is moving at the same velocity as the linear wave 292000 miles/sec
                            so if (and its a big if) my conjecture here is something like right I really don't know what might happen . I'm sure you can see how an anti gravitational situation could quickly arise .
                            And how it could possibly be done with no core at all . As I say this has only just crossed my mind I can't think of any way of testing the veracity of what I suggest just at the moment .. but it does seem to join a few dots for me . Including possibly the Hendershot device and the gravity waves found thread also starts to make sense. I know I'm pointing you straight at the unknown … but in the right area I'm sure. Its what we want to know and have been considering for a long time anyway isn't it ?
                            • #74
                              Duncan
                              I always enjoy your posts , and while on a mental lunch break at work, I find my mind swimming with innumerable thoughts popping in and out of existence, like those pesky particles around the dipole that Bearden likes to mention every so often. I'll try and grasp a few to weave together a coherent line of thought...
                              It seems to me you are talking about the interrelationship between electricity, gravity and magnetism. I assume your reference to the linear impulse or wave is interchangeable with longitudinal or scalar impulse. It's interesting to note that these impulses, though often referred to as waves are really vectors - of which I'm sure you're very well aware; hence the term "impulse" which you use.
                              It makes sense that we widen our electro-magnetic-gravitic paradigm to include longitudinal or scalar impulses/vectors. Otherwise, we will never really get off the ground - hehe. I'm convinced that this is the technology behind the flying saucer stuff we've seen since the 1940s 'til present day. Why pin this on some big-eyed extraterrestrial green or grey critters, when it's clear that the Germans, Russians, and likely later, the Americans have been playing with it for decades.
                              There've been reports of anti-gravity surrounding the Joe Cell - which as I see it, provides a kind of vortex for condensing aetheiric energy or orgone to energize an engine or battery, or to supercharge water. Weren't there some gravitic anomalies anecdotally ascribed to some of Bedini's early work?
                              EPD makes repeated reference to the fact that the sun's energy is really in another dimension. It seems scalar lines of force share a similar characteristic of other-dimensionality, propagating at supraluminal near-instantaneous velocity. Human intentionality is also said to have this same characteristic as scalar in nature. Its in another dimension, yet produces physical change in objects and substances (let alone people) at a distance.
                              I keep going back to Tesla's series-wound bifilar pancake coil with its mutual cancellation of magnetic fields, and how it produces or perhaps liberates scalar vectors, and how it figured into so many of Tesla's patents in one way or another.
                              My lunch is pretty much over, and something of the mystery has begun to further coalesce into coherent understanding after reading your words. I wonder now what we need to do to get to the next level.
                              Is the sun just a spherical concentration of scalar energy, condensed from the universal aether? Do the planets in their orbits, turning on their axes provide us with the grand paradigm for understanding the action of a swbifi pancake coil with its mutual cancellation of mag fields and liberation of scalar lines of force?
                              UFOpolitics showed that radiant energy was most concentrated at the centre of his pulsed coils. Might it also be with scalar "energies" at the centre of a swbifi pancake coil? Might this also be a microcosm of our solar system?
                              Forgive me if I rambled or led things off course (I hope not). Just trying to pull things to gether and understand, 'cause we're really not in Kansas any more...
                              Back to work Bob.
                              • #75
                                Magnetism is my focus on the forums.
                                Yes, straight boring magnet kind leading into the transformer. I haven't delved into the resonance because I am still crawling and haven't learned to walk into it yet. However from my observation of emf and magnets I have this to say about the inexplicability of the transformer. The path runs both ways, Clockwise in the core would mean counter clockwise outside the core. Once the outer field intersects the secondary winding it causes the reactionary field that would then couple with the core causing a vortex like assimilation then collapse.
                                The thing about the coil is most people don't appreciate the effect that each individual coil has on the whole The first winding is pristine involving a near perfect tiny orbit of flux. but every winding there after ads to the reluctance. If you think about it a coil generally has so many points of reluctance that flux is squeezed out literally out like a rail gun.
                                If you hold a magnet to steel the physical force exerted is as if you where trying to keep your hand away from a small breach into outer space. Modern Neo magnets are reputed to loose less than 1% of their pull every 10 years. Studying Neo magnets and Hallbach arrays I eventually determined that it would be possible to create a motionless generator by simulating the Hallbach with three trigger coils with two permanent magnets between and collecting the total output . it wasn't until a few months later that I discovered the Bearden Meg. Oh well so much for my originality. But to my surprise no one can seem to get one functional successfully. So I continue down the rabbit hole undeterred. I study the reaction from that single wire. Reluctance, impedance, saturation, permeability all are pieces of the puzzle of finding the secret of the seamless assimilation of usable energy from permanent magnets. I simply see magnet reactors as a scalable power solution once deciphered.
