I have an idea for a generator that combines a few other designs.
Mainly the SEG and Faraday's
![](http://www.zamandayolculuk.com/cetinbal/FJ/faradisk1.gif)
Plus this coil configuration "The Angus Effect" - YouTube
I am not sure if it would work as I vision. I have attached a rough drawing.
I don't believe that the rotating mag rotors will induce a field in the u-bolts since the magnetic field never "leaves" the bolt, however the field will be rotating so it may? I shouldn't be able to get a current in the copper plate since the drag will be used to rotate the magnets, however, since the rotor is traveling in a circle the outer magnets must rotate faster than the inner, so a current may be able to be induced?
I am in the process of a move and have a baby on the way, so I don't have time to throw this together for a bit. I would appreciate some input on this good or bad.
