Analysis of the WITTS Generator
  • Analysis of the WITTS Generator
    Version 1.0.7.D
    Released on February 14, 2014
    Download Your Free Copy
    Originally posted by Analysis of the WITTS Generator
    Two possibilities exist with respect to the above device.
    One: It's a fake.
    Two. It might be real.
    For all of those who believe it's a fake, I say to you, “Congratulations. You're done. Perhaps, it's possible for you to realize that there is no need for you to try to convince others to believe as you do. I would like to suggest that as long as you securely believe that the device is fake and you're okay with believing that, then that should be enough for you; however, if you're not satisfied with that suggestion, then I suggest you write and publish your own ideas as to why the device is a fake.”
    The other possibility exists that the device might be real. If the device is not a fake but real, how would such a device be constructed? What might be its operating principle?
    VIDBID
    Patent US381970 - Nikola tesla - Google Patents
    Non-saturating magnetic fields in iron cores are compressible/flexible + movable/tunable + capable of generating transducible (back-EMF-like) field reversals, though where any transduction winding connections can simultaneously current-interact with reversal activities.
      Comment by GSM
      Thanks, GSM.
      Well said. Now if I could only understand it. Well, I'll try. LOL
      What if I fed only half a wave into each group of the two groups? See the document. What if I took the cemf from the primary coils and used it to charge caps in a snubber circuit. I guess I could feed that charge back to the battery, but I'm getting ahead of myself. I've got an idea for a solid-state circuit. I hope to include it in the next update of Analysis of the WITTS Generator
      VIDBID
        Originally posted by vidbid
        Version 1.0.5 is now available.
        Download
        Thank you for setting that out so clearly Vidbid.
        Yes, the switched input compresses opposite segment fields within the core's circumference, but causes the resultant field to be flexed over the ring diametrically, instead of circularly through it.
        The speed/timing of segmented flux compression/induced oscillation must be tuned to relate to the Fe core material and its cross-section construction, whether solid = slow and very lossy, or laminated, or wire, or ferrite, or a hollow sleeve/tube = fast and ultra efficient (as in Hendershot Mk3 at a higher frequency) in order to optimise transducible diametric output with minimum drive quadrant loading.
        Cheers ............... Graham.
          And the whangdoodle must operate in resonance with the whatchamacallit
            Update: 1.0.6
            My pleasure.
            Thanks for contributing your ideas to this thread.
            By the way, the latest version is available for download.
            Please see Post #1 of this thread.
            VIDBID
              Tesla's Two Phase Circuit
              I think it's important to note that this circuit won't power a load on only one phase. It requires two.
              Run Simulation
              Regard
              Vidbid
              VIDBID
                Parallel v. Series
                Run Simulation
                Vidbid
                VIDBID
                  Calculating Inductance of a Coil
                  Calculation of inductance coil - YouTube
                  Also, I believe that there are meters on the market that allow you to measure a coils inductance.
                  Berg
                    Half-toroid Generator
                    http://www.energeticforum.com/energe...tml#post251289
                    Patent award on a generator that looks something like the WITTS Generator.
                    Vidbid
                    VIDBID
                      HA HA HA, they have one of my videos contained within that paper. Very interesting. Thanks!
                        Hi Vidbid
                        Thank's for sharing this info on the "motor -generator"
                        So i had some time today to replicate this experiment
                        So i cut one of my big ferrite torroid in 2 parts, and wind one half with 700 turns of 0.3 mm copper wire (11 ohms DC resistance and 39 mH inductance ).
                        Than i fixed a diametric neomag cylinder (i got from a high quality Faulhaber motor ) on the shaft of an electric motor. And made some testing.
                        But the result is a nice sine wave on the scope under no load, and clearly Mister Lenz is operating when i short cut the coil. Almost double Amperage with load versus no load.
                        So i tried a lot of speed, but no way to get the acceleration and decrease of power when the load is connected.
                        I remind that my core is in ferrite, and perhaps the "secret" is in a plain steel core . But no succes for me so far.
                        And an other experiment and learning.
                        Good luck at all
                        Laurent
                          Hi Laurent,
                          Perhaps the distance between the magnet and the half core also counts, I mean the ratio of the magnet diameter to the (inner) diameter of the (half) core: your magnet seems to be big in this respect (if I compare it to the setup shown in the second video).
                          Perhaps if you happen to have smaller magnet, about half sized in diameter compared to the one in your picture, also magnetized diametrically?
                          (The closer the magnet to the core, the higher the Lenz effect becomes.)
                          Regarding steel core, it must be laminated because otherwise eddy current losses do occur, your ferrite must be good in this respect. I hope the core shown in the video test is not a solid iron (even if it is soft iron, it should be laminated).
                          Regarding your load, you may wish to use a 10 Ohm resistor instead of the the short circuit, perhaps it also helps seeing the effect. In the second video the input current changes i.e. reduces very little: from about 1.0 - 1.01 Amper to 0.99 or so for the unloaded - loaded case, this may indicate a narrow operational window for the effect I guess.
                          Thanks, Gyula
                          • #14
                            Flux Containment Module
                            Hi Vidbid
                            Good luck at all
                            Laurent
                            Hi Laurent,
                            Very good experiment. Thank you for sharing your experimental results with us.
                            In terms of a generator, it is truly a mystery at this point.
                            By the way, I am thinking of an experiment for my Flux Containment Module.
                            http://www.energeticforum.com/renewa...tml#post251321
                            Kindest regards,
                            Vidbid
                            VIDBID
                            • #15
                              Originally posted by gyula View Post
                              Hi Laurent,
                              Thanks, Gyula
                              Hi Gyula
                              Thank's for input
                              Yes if this system really works, it is perhaps in a very small window.
                              Just for info, i have tried the 10 Ohms resistor instead of the shortcut, but Lenz is clearly there also.
                              Concerning the diameter ratio, it seems that in the first vidéo, they are using rows of neomag organised in circle. With one half of the circle oriented N and the other oriented S forming a big diametric ring magnet probably as big in diameter as the core of the semi cylinder coil.
                              I will wait if somebody else will replicate the system, to see if there can be a positiv result. But the result of this first experiment seems clear enough to me ,
                              With my replication, Lenz is too much present to give real hope of a positiv result and so i am not encouraged to insist if i can not get much more precise infos or " little secret" delivery.
                              Good luck at all
                              laurent
