Analysis of the WITTS Generator
  • What does your first quote suggest about the second? One needs to
    have an accurate theory of overunity operation before one makes
    design changes. On the other hand overuntity critics have *no* clue.
    :S:MarkSCoffman
    Very true,
    On the other I can understand HopeGirls position that the world can't wait.
    So they spend a little of their patrons money to develop it on the fly.
    The point is we are all involved in the process either way.
    This is the point of her message. Absolute transparency in all human systems.
    Nothing ventured nothing gained.
    In reviewing the 16 Kw Whitts video, T. Thrapp was careful engaging load onto the generator above what was require to self run the DC motor.
    This was interesting to watch. He slowly added light bulbs until all were engaged.
    To the clueless, a small machine might be of value.
    Potential, is a terrible thing to waste.
    • HV burn through
      If the QEG really did burn through on the "vibrating " coils then this might be a good sign that the device might really work considering there is no voltage input to the circuit. Sucks for the set back though.
      • HopeGirl Removes Taiwan Video
        HopeGirl took down her video. From what I read, I believe the reason is she is afraid of exposing Chinese students working on the project to governmental scrutiny.
        Berg
        • Chinese Faces Blurred
          HopeGirl's Taiwan video is back up but with the faces blurred.
          Copy of QEG Taiwan Has Resonance!!! - YouTube
          Berg
          • Just asking, why does the exciter coil also has coils on the inside, or does the core have spacings in it? Or am i missing something?
            Greets JB
            http://youtube.com/johnnblade
            • Originally posted by JohnnBlade View Post
              Greets JB
              The exciter coil is wound on clear acrylic tube.
              • Twenty-first Century Quantum Energy Launched
                Launched 2014.04.04
                Youtube video: Quantum energy belongs to the people.
                VIDBID
                VIDBID
                • End Plate Drill Jig for QEG
                  Interesting website for QEG manufacturing.
                  End Plate Drill Jig For QEG Manufacturing UFO-Disclosure.net
                  Drilling QEG End Plates With a Wound Core UFO-Disclosure.net
                  Berg
                  • This Week in Free Energy - April 3, 2014
                    This Week in Free Energyâ„¢ -- April 3, 2014: QEG, YMNEE, H-Cat - YouTube
                    Report on the QEG.
                    VIDBID
                    VIDBID
                      The addition of component images might help people see what is what.
                      VIDBID
                      Dear VIBIAD what is the capacitor values for the series parallel capacitor bank ???
                      • mini-QEG
                        Hi Stephen Brown,
                        thanks for your feedbacks. Your mini-QEG idea is interesting. I was also looking for a way to assemble a smaller proto for the sake "proof of concept".
                        The big advantage with a demountable core would be to can wind the coils easily. But the big challenge here is the unavoidable gaps you get in those 23 degrees chamfers, even working with extreme precision, you will get tiny gaps which will cause leakage fluxes. One should use thin bended (arcuate) pieces piled up overlapped like a brick wall. This would be very costly with ferrite, but with 2 or 3 different forms of arcuate silicon steel sheets, including the salient parts, it could offer a solution.
                        Best regards, parametric.
                        • to Gizeh
                          Hi Gizeh, thanks for your appreciation and feedback info. I am based in South Am.
                          All the best, parametric.
                          • Vidbid
                            I think this drawings are wrong, as the coils did burn at the Prototype. I think they got at all 4 sides from the core #20 wire, like at the tesla Patent best cop. When you look at the pictures, they coils look all pretty equal wound. I think you would see a difference, when the half coils have only #10 wires on it and 2 others 3200t #20 wire (and maybe #10 above).
                            • Originally posted by Ajnabii View Post
                              I believe there is a high definition picture of the WITTS generator's capacitor bank somewhere out there in cyberspace, but I don't have it.
                              I would think that if the capacitance and voltage rating for the capacitor bank of the WITTS generator is the same as that of the QEG, then it should be easy enough to calculate the individual capacitance and voltage rating for each capacitor of the WITTS generator's capacitor bank.
                              VIDBID
                              VIDBID
                              • Originally posted by Joit View Post
                                Vidbid
                                Joit,
                                I'll have to look at it again more closely this time, but I hear that the windings on the core weren't treated with much care. A huge amount of weight was applied to them. I think that could have caused problems. I agree that eye bolts need to be attached to the core, so pressure is not applied directly to the windings.
                                Another thing is not enough insulation on the windings, especially, the high voltage windings. I own an old fly-back transformer from the 1970's. That thing is encased in some type of HV resistant synthetic rubber. The QEG probably needs something along the same lines.
                                VIDBID
                                VIDBID
